SteamPunk Your Lead Pencil by ezarate
Steampunking anything is really easy!
all you really need is a plan and a idea and that's it!
just get a bunch of wire gears and spare parts and put them together to make something new,
below are pictures of what this instruct able is all about.
i will not show you how to make this led pencil exactly!!!
i will show you what you need and how to start off but you should make your own design!!!
it only took me about 5h to make it. mainly because i had to let the quick dry glue dry.
Step 1: Pencil
first find yourself a fancy led pencil that's made out of metal like the picture shows below.i got my from Big Lost it costed only 10$ a set of the led pencil with 2 pens. Try to get one that has a golden tip and a golden eraser cover, it usually indicates that the metal casing is also golden once you remove the paint.
vampir_jester says: Sep 6, 2011. 7:20 PM
i would have used a different watch instead of a waltham repeater which is worth around $200 give or take. I'd suggest researching your materials before you tear them apart.
ezarate (author) says: Oct 27, 2011. 7:22 AM
lol that watch was worthless it wasn't a waltham repeater. we looked everywhere to try to make a profit out of it but it was useless. so i found a use for it.
MurphyHarris says: Mar 18, 2011. 7:21 AM
good look. But steampunk stuff should be usable. you could drill small holes in the pen. a drop of superglue on it. managed to hold the gears.
3 stars.
ezarate (author) says: Mar 20, 2011. 10:05 AM
and yes you can write with it it does nothing to bother your normal writing skill
ezarate (author) says: Mar 18, 2011. 9:42 AM
the gear are held on there very nicely without the holes. the problem is that the gears wont turn. im thinking about drilling holes big enough for the drills and adding a metal peace to the other side holding the gear in place, this way itll turn.
zazenergy says: Mar 7, 2011. 5:41 PM
Cool! FYI, the title should read "Lead" and not "Led"
ezarate (author) says: Mar 8, 2011. 6:05 AM
haha my bad xD its fixed
ezarate (author) says: Mar 6, 2011. 4:35 PM
ADD PICTURES OF YOUR WORK I WANNA SEE YOUR FINAL PROJECT :D
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
