iImage Information
I don't know whether I quite understand what makes something "steampunk", but one of the common characteristics seems to be the use of metallic finishes (especially copper and brass) rather than the modern paint & plastic look. Well, you can get Aluminum TAPE in most hardware stores, Copper TAPE in better garden shops (snail deterrent), and brass "shim stock" (foil, in thickness up to "pretty thick"), so it seems to me that you can potentially make things somewhat steampunk-like pretty easily, by applying tape and foil to "ordinary" objects.
In this example, I use some copper tape to make an altoids tin look more steampunk-like. (I guess the other thing I've noticed is that there should a relatively high degree of customization, so this is probably
only partway to being a complete steampunk-like project, if I'm headed in the right direction at all.
(Of course, I imaging for "real" steampunk, you're not supposed to cheat like this at all; if you can't machine your altoids-style box out of a solid block of copper, you should at least fold it yourself out of sheet metal. Still, I like to cheat!)
http://www.eyeletoutlet.com/
The next link has the ones I thought of for steam-punk or old fashioned style
http://www.orientaltrading.com/craft-and-hobby-supplies/scrapbooking/eyelets-a1-388824-2-1.fltr Second row, second item.
In both pictures you can see the shank would have limited usefullness for thicker items. However, the measurements they are giving is the diameter. I am sure you could find eyelets with longer shanks as well, just have to look.
Then tweak it up with the ideas that shooby puts forth a couple of posts down, and you get the general idea.
It's all about making it look very Victorian, and also giving a look that reminds one of the beginning of the Industrial Revolution. Add decals such as you would find on Dr Pemberton's Pick Me Up (cures what ails ya!), or any flowery font that you would find in a turn of the century Sears and Roebuck catalog.
I hope this helps.
P.S. A shiny new quarter to anyone who can tell me what Dr Pemberton's pick me up is.
your so far off the mark there. The Victorians were the inventors of disposable tin packaging, just look at snuff and tobacco tins of the era, may were identical to the contemporary Altoid Tin.
Cheers!
- I'd say this really isn't Steampunk.
Of course not, and I said as much in the comments. It's a hint toward easily creating things with a "steampunk look", at best...I sorta prefer to think of it as making high-tech gear have the sort of hand-made "work of art" look that pre-dates the industrial revolution. But it doesn't seem that I have a very good handle on the whole concept, so don't listen to me!
The Girl Genius Comic abounds with examples, I think.
For inspiration, take a look at Dave Veloz's amazing Mac Mini Mod:
http://steampunkworkshop.com/daveveloz.shtml
