3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Steampunk Electro-Optical Logic Machine
  • last photo ←
Could a digital computer have been built prior to 1900?  Babbage's Difference Engine shows one possibility of a mechanical computer but what about an electrical approach.  The Steampunk Electro-Optical Logic Machine uses photoconductors and gas discharge tubes which were both in use by 1880 to form a NOR gate logic array.  The principles of Boolean logic were also available by this time to assist in the systematic design of such a device.  The routing of light through total internal reflection had also been demonstrated.
Although the specific materials and methods used here would not have been available by 1900 this device is interesting as a way to visualize how  the basic logic gates; AND, OR, XOR, XNOR, Set/Reset Latch and D Latch can be formed by connecting NOR gates.  This breadboard also can be "routed" while it is powered up.  Results are immediately visible without having to use an oscilloscope or voltage meter.
A word of caution this circuit is powered by 110VAC.  Observe all pertinent safety precautions when building, testing and using the circuit.
Videos of the circuits can be seen here:
http://youtu.be/n1Yoi3GIyW4
http://youtu.be/m6MZZ45RIqI
More background info available here:
http://twincitiespianolab.blogspot.com/2011/11/optically-routed-nor-gates-1.html
12 comments
Jan 10, 2012. 7:34 PMalisonjeancole says:
This is so great.
Jan 4, 2012. 9:10 PMelectfire says:
Speaking of computers, have you seen some of user, Horatius.Steam's computers? He got some neat computer case mods... true they're not as pure Steampunk tech as yours is, as they are modern computers.....
Here's some links to some of his computers (If you don't mind):
http://www.instructables.com/id/The-Dragon-a-desktop-computer/
(My favorite)
http://www.instructables.com/id/The-Cockworkers-Server/
(Clockworker's,for some reason the link is misnamed)
and
http://www.instructables.com/id/Buidling-a-Steampunk-mini-computer-for-the-Ladies-/
(My second favorite)
Jan 5, 2012. 7:07 AMelectfire says:
That is neat! On a side note, love the pictures of the Steampunk Tardis, that one of his friend was working on...
Jan 2, 2012. 8:04 PMelectfire says:
Evidently I have been influenced by Richard Nagy's (Datamancer's) work, more than I realized. Cause at first I thought this was a scanner inside of a book, like his....
This though took me by surprise! I am looking forward to more details.
Jan 4, 2012. 4:33 AMmycroftxxx says:
Even if you only get as far as a few basic computing elements, I think you may have won steampunk computing.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:MPLS_CBG
Wide range of interests supported by my day at Medtronic.
