3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Cyber/Steampunk Futuresque Sci-Fi Hand Gun
Step 2Adding the Hinge
Adding the Hinge
Right, the main part of this gun is based around this hinge, i got it from my local wickes, its used to hold a door onto a cabinet, and has a wide opening angle, im sure this type of hinge can be found in many places. The brand name on the hinge is Lama.
Picture 1
- Line up the hinge with where you want on the card section
- Draw around the outside, then trim away
Pictures 2&3
- Tape the hinge in place.
- Cut and attach some sections of card around the outside on the hinge (this will vary from hinge to hinge)
- you should now have like a hole with the end of the hinge seated on it.
- Fill the hole with PVA, making sure to fill the gaps
- let it dry, there will no doubt be gaps in the PVA from where it has soaked into the corrugated board, so top it up, and let it dry again
Pictures 4,5 & 6 show the hinge in place (ignore the metal rod, another failed attempt at a barrel)
3 comments
Apr 22, 2011. 2:04 PMnomuse says:
That's great! I know those hinges...but when I saw the video, all I saw was a cool-looking mechanical part that totally looked designed for the gun. That's always wonderful when a found object integrates so well it no longer looks like a found object.
Sep 24, 2011. 10:32 AMTheGreatS says:
Where are these hinges? I have looked at Home Depot, Lowes, Online at Lamas web sight and on Wickes website. It's the elusive yet ever so necessary hinge.
Jul 30, 2010. 1:29 PMstarfox384 says:
Where do you get the door hinge????
Sep 19, 2010. 6:46 AMIrwind Kee says:
get from your door, or from local hardware store
Sep 19, 2010. 5:56 PMstarfox384 says:
I looked at lowes and they didint have the right one
Sep 20, 2010. 10:14 PMIrwind Kee says:
maybe you can replace with similar part
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
589
Author:gmjhowe(gmjhowe graphic design)
I am a British Graphic Designer, when I am not working I spend my time making an array of projects, from electronic instruments and chessboards to cyberpunk rifles and steampunk props. If you have an...
more »
