3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Cyber/Steampunk Futuresque Sci-Fi Hand Gun
Step 6Add the glow
Add the glow
Ok so ive not soldered for like ages, so this bit took me a short while
Pictures 1&2
- i put together a simple small circuit using a switch, and led and two 3v button batteries
- I made two metal contacts from an old floppy disk
Pictures 3&4
- Cut out a channel from the gun, this runs from the front of the gun to the bottom of the handle
- Also cut out a slit in the back of the handle to store the batteries
Its up to you where u put the switch and batteries, i just put them where they would sit nicely without compromising the strength.
As you can probably tell, i originally planned to have the ammo in the handle, so my switch is at the bottom, cos i already had a hole there.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
589
Author:gmjhowe(gmjhowe graphic design)
I am a British Graphic Designer, when I am not working I spend my time making an array of projects, from electronic instruments and chessboards to cyberpunk rifles and steampunk props. If you have an...
more »
