3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Steampunk Goggles
Steampunk Goggles
I wanted to make a pair of goggles myself, and not spend too much money on them.
This is the result. I spent under 10 Euros, and had hours of fun. They took me about 5 hours to make, including taking apart and putting together again many times, to make sure everything fitted correctly before the next stage.
I recommend every beginning steampunker trying a pair of goggles, it's fun! And you end up with something unique.
I'm not 100% happy with these, but they'll do for this year's Elf Fantasy Fair. Now I need to make the rest of my outfit.
 Stuff:
- 2 small candy (sweet) jars with metal lids and transparent inserts (1,38 for 2 at Xenos), use the lids, recycle the glass;
- M4 bots and nuts, bolts 10mm long; M4 blind nuts;
- aluminium strip, 10mm x 2mm x 2m long (I still have a lot left);
- leather (I bought an old, worn leather jacket at the flea market, great texture, I've still got lots of it left for other things);
- some rings cut off a round syrup bottle that was almost the same size as the jar lids;
- rusty old rings from a backpack that I threw away;
- old clock parts (bought at the flea market, it's amazing what people sell, and what people buy!);
- brass wood screws;
Tools:
- hammer, pliers, screwdriver;
- drill and drill bits, steel nail;
- scissors, hobby knife;
- leather needle and thread;
Step 1Basic shape
Basic shape
When deciding the design of the frame, I considered my nose. What would sit comfortably and be relatively easy to make. I decided on a strip across the tops of the 2 eye pieces.
I first measured the distance between the eye pieces when over my eyes, roughly 2,5cm. Then I estimated the length of the strip required, plus a bit to be sure, this was 13cm.
I cut the aluminium strip and bent it by pushing and hammering around a wooden pole. Luckily aluminium is easy to bend, so this wasn't too difficult.
I then drilled holes in the strip, then tried to drill in the eye pieces. As they are very smooth and have grooves for the screw cap, I had to hammer a steel nail in the correct position first, then drilling was easy. I used a piece of wood to prevent the drilling squashing the eye piece.
I tried the basic goggles on for size and found I needed to bend them out a bit to fit comfortably.
12 comments
Mar 7, 2012. 3:29 PManibioman says:
very nice very simple this is something i really might achieve
May 30, 2011. 6:40 AMzen of zappa says:
Whoa! So cool! These goggles will be my first steampunk item to make, but I was wondering if you can possible alter them to make them glasses? And use a darker lens to make them sunglasses? Heck, I might even wear these as I would any normal sunglasses during summer. Looks like a time travelled right to the beach...
May 30, 2011. 6:38 PMzen of zappa says:
and where would you find lids like that?
Oct 18, 2011. 6:18 AMYitzki says:
I found very similar lids at my local DeSerres, so I would imagine they would be at most art stores.
Oct 18, 2011. 9:59 PMzen of zappa says:
i happened to see another instructable for goggles and they use the two ends of a coupler. i am guessing it will work the same way, plus i can unscrew the thread part to put in new lenses. my goal is to get a slightly modified version of these done for halloween, so hopefully i shall post pictures then!
Mar 15, 2011. 6:31 PMilpug says:
Very nice. Am thinking about making some of these. maybe you could show us the completed costume?
Mar 7, 2011. 4:52 PMzazenergy says:
Gorgeous!
Mar 6, 2011. 11:18 AMlemonie says:
Nice.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
6
Author:Mage and the machine
