Steampunk Necklace From Leftover Pipe and Bottlecaps
3,680
96
8
Published
Introduction: Steampunk Necklace From Leftover Pipe and Bottlecaps
About: Art+Manic Depression/Bipolar Disorder=Me. I've always loved creating art but it used to be dangerous for me because it would trigger Manic episodes. Thanks to some recent changes I've been able to safely div...
Jewelry made from 3/4" wide copper pipe and bottle caps
Step 1: Cut the Pipe
Use a tube cutter to cut your 3/4" diameter pipe to the desired length. I used 2 " for the longer and 1 and 1/4" for the smaller one.
Step 2: Dome the Bottle Cap
Use a dapper to flatten the edges of the bottle cap white turning it into a dome
Step 3: Drill Hole in Bottle Cap
Drill a hole in the center of each bottle caps
Step 4: Cut a 10" Piece of 16 Gauge Wire
Step 5: Prepare Wire for Bottom Cap
About 3" from one end bend the wire at a right angle then continue to make a loop
Step 6: Attach Bottom Cap
Place wire through hole in cap
Step 7: Make Round Loop on Outside
Bend wire into right angle then continue to wrap around to make loop
Step 8: Add Center Pipe and End Cap
Before you add the pipe you can embellish it or leave it plain. On the long one I drilled holes and attached metal fasteners( normally used for scrap booking and mixed media) one the smaller one I attached a small metal tag that I had stamped out the word wish. Use your Imagination.
Step 9: Add Top Loop
Make top loop,ing the same way you did the bottom. Great job.
Step 10: Finished Projects
    • Slow Cooker Challenge
    • Spotless Contest
      Spotless Contest
    8 Comments
    awesome, you inspired me :-)
    Wow, really original idea!!
    Very cool! These are funky and original, very nicely done! :)
    Thanks so much! This was my first post so I really appreciate the compliments
    You betcha. I hope you'll share more of the things you make! :)
    These are awesome! I'll be making some these afternoon.
    Good luck! I'd love to see how it turns out.
    Wow these are great! I will definitly have to play with this idea.
