Steampunk Picaxe protected Sketchbook by Admiral Aaron Ravensdale
Featured
A new artifact has left the Steampunk Design workshop and got a new place on my desk.
Everyone knows that Steampunker have countless ideas and projects which must be stored safely until all the parts are available or the last problems are solved.
From my experience, some ideas needs a few months of planning until they are really ready to be implemented.
In order to work in this time the ideas are not forgotten or are even get stolen from curious colleagues, they must be drawn and written carefully down and kept highly secured.
For this purpose, I have developed this sketchbook.
It has a two-way protection.
The first is a combination of four switches, each with 4 steps, thereby resulting 265 possible switch positions. If the right one is found, only the circuit is closed and the PICAXE starts to work.
Now the second security system comes to bear.
It must be entered the right knock code!
If this code entered incorrectly a fitting melody played and a cooldown time of 80sek starts. Only after this cooldown time a new attempt permitted.
When the right combination is found you will hear a different tune, and the book will open.
If you want to close the book you must push a small hidden pushbutton.
But look for yourself: In HD mode you can recognize all the small details.
Partslist:
- Paper Blanks book Grolier Grande 35€
- Picaxe 08M Modul (AXE230) 20€
- Piezo 1€
- Switch 4x 4-positions10€
- Servo micro 10€
- Nokia BL-5C battery 8€
- Brass pipe 4mm 6€
- Brass pipe 2mm 4€
- Brass pipe 1.5mm 2€
Step 1: Modify the clip
First of all i buy one of this really great looking Paperblanks books from the Grolier edition.
The main reason is that they already have a metal buckle to close it.
With only two small modifications I was able to prepare it for my project.
First of all I remove the small magnet inside the buckle with a sharp knife.
Then I solder a brass pipe which I cut in a little bit over the half diameter instead of the magnet.
Then I push the old splint 1.5mm out of the buckle adapter.
This hole I drilled up to 2.1mm.
Make sure your 2mm brass pipe moves very smooth through both holes.
If you lift up the buckle and stick the 2mm brass pipe inside the book is locked.
eage says: Jan 18, 2013. 1:52 PM
This makes me want to play Myst.
nerd7473 says: Apr 10, 2013. 4:07 PM
what is myst about?
nerd7473 says: Apr 10, 2013. 4:13 AM
where can I get that notebook, or one similar?
Admiral Aaron Ravensdale (author) says: Apr 10, 2013. 6:26 AM
from amazon search for Paper Blanks Grolier Grande
nerd7473 says: Apr 10, 2013. 11:21 AM
thanks
batonas says: Jan 24, 2013. 4:39 AM
now thats impressive! I have an idea that would make your project even more steampunk, and that would be changing the wires with conductive paint, that way you could save some space make secret switches in your graphic painting on the cover of your sketchbook, good think would be to hide all the electronic components, the servo locking system looks really neat, but it have flaws, like you said you can turn it by hand or with pliers, and its kind of exposed to much, I would change it with two relay lock they would lock be locked in place by spring and unlock when the current is flowing, I would hide them in in large metal lock mechanism similar to old suitcases, I'm not criticizing your project at all, its great, you put a lot of effort and creativity making it and I admire that, its just my way of making it, I have lots of ideas for projects and stuff but I'm just too lazy to make it, hope you use my ideas in your new sketch book when you fill this one. keep up the good work, and good luck.
einstein6 says: Jan 21, 2013. 9:13 PM
This is one of the most awesome idea I have seen.. Very creative indeed..
Cuitlahuac says: Jan 18, 2013. 12:53 AM
WOW, this is a great great idea, although I don´t use notebook very often I love this stuff. Thank´s!
Carlos Marmo says: Jan 17, 2013. 12:20 PM
WUNDERBAAAAARRRR!!!
criggie says: Jan 17, 2013. 11:25 AM
Loverly idea - could you put either some brass paint or some brass nipple covers on the four plastic switches? Obvious plastic is bad in steampunk.
Another idea would be to have a way to replace the bound paper once you've filled it with your writings.
Can you turn the servo by hand without the correct code set?
Admiral Aaron Ravensdale (author) says: Jan 17, 2013. 12:17 PM
Thanks.
If you take a look on the youtube video you will see that i take brass paint on the switch until i found some usefull brass knobs or balls.
I think it need some years until the book is full then i built a new one :-) i an other style.
Yes you can turn the servo by hand but it is not so easy that you make it in seconds without any effort. And if you turn it the gears inside make a scary noise. It is faster to take a pliers :-)
filtercages says: Jan 17, 2013. 10:33 AM
Just great!
I love the old book style especially - I' going to see if my grandson aged 10 will make this with me.
EvilDefman says: Jan 17, 2013. 10:24 AM
Won't work for a deaf!
BrittLiv says: Jan 17, 2013. 8:44 AM
This is very smart. I'm for sure going to use the mechanism for something and you are a fellow German!
throbscottle says: Jan 17, 2013. 6:02 AM
Awesome and gorgeous! I must make one of these - heck make several - the grandkids would love them!
Admiral Aaron Ravensdale (author) says: Jan 17, 2013. 8:28 AM
Let me see some picures if you have it in your hands...
mgrundvig says: Jan 17, 2013. 7:40 AM
Very nice! Beautiful work and a fun piece! I love it!
lootsvele says: Jan 17, 2013. 5:00 AM
This is wonderful! I love the details! <3
Lotus
Thetis says: Jan 17, 2013. 3:56 AM
I'm not sure your knuckle joint needs to be soldered in the awkward way you describe. I am a watchmaker and regularly fix broken metal straps which are also effectively a series of knuckle joints. I would drill a hole through both the 4mm and 2mm brass tubes. Then you find or make a slightly tapered pin and drive it through the holes until it will go no further, then file it flush. Taper pins can be bought, or made fairly easily with no more than a pin vice and a file.
Thetis says: Jan 17, 2013. 4:00 AM
PS - I should have said.... cool project!
electfire says: Jan 16, 2013. 10:59 PM
Congrats on making Hack-a-Day with this project!
(and sorry I didn't comment on this sooner!)
Here's the link to the Article:
http://hackaday.com/2013/01/16/a-steampunk-combination-sketchbook/
Patrik says: Jan 16, 2013. 12:15 PM
Very nice!
Now we just need someone to take up the challenge to hide streamline of that hardware so it's flush with the covers. Maybe if you pick a set of covers that juts out beyond the pages somewhat, one could put all the locking mechanism there...
Junophor says: Jan 15, 2013. 2:28 PM
Dear Sir Admiral Aaron von Ravensdsale
Ho can I tell you in how deep impressed I am?
It is so awsome, unbelievable great!!!
Take a bow!!!!
Ten Stars worth if that would have been possible
Yours Aeon Junophor
build52 says: Jan 14, 2013. 5:32 PM
That is AWESOME!!!
That is AWESOME!!!
Thergox says: Jan 14, 2013. 4:17 PM
Oh my. . . That is gorgeous. I really wish I knew a place with those materials >_< This is an amazing Instructable. Thanks for sharing!
oldmicah says: Jan 14, 2013. 4:00 PM
Awesome! I love a lot of steampunk projects but functional ones are incredible.. Thanks for sharing!
GorillazMiko says: Jan 14, 2013. 10:05 AM
Well documented, great photos, great project.
Teach me your ways.
GM
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
