3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Steampunk Pirate Gun Mod
Step 4Faux wood finish
Faux wood finish
My technique achieved a worn mahogany look. I am certain with a little tweaking one could achieve different "stains" of their choice. This took about a half hour from beginning to end. It would take longer if you wanted the paint to dry completely before sanding each layer, which you will see I didn't in my tutorial):
Paint a basecoat of black all over. I used spray paint in this step since the surface is not as detailed, so covering was easy. Let dry 10 minutes.
Then apply a layer of the yellow acrylic using a crumpled piece of paper towel. Do this by dipping your paper towel into some of the paint, then dab it against a paper bag or newspaper, to take some of the paint off and get a more dry-brush application.
Apply the paint with the wadded towel, drawing it in long strokes in a uniform direction--namely the direction you imagine the grain of your wood would run. Make sure you are getting a little striping, and you are getting plenty of the black showing through.
This can be done with a rough paintbrush if you prefer, but the paper toweling works just fine for me.
3 comments
Feb 1, 2008. 4:29 PMGernader8 says:
Great tutorial so far. What did you do to prep the plastic before painting? Use a rough sandpaper so you could get a "grain" in the plastic?
Feb 1, 2008. 6:19 PMGernader8 says:
Thanks, wasn't sure if you did anything else special for this step.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
14
Author:TribalDancer
