Steampunk Segway ( Legway )
Step 2Build Pedal Shafts
Build Pedal Shafts
Materials
(2) Galvanized 1/2" pipe flanges
(2) 1/2" black pipe pieces 8" long
(4) 1/2" black pipe elbows
(2) 1/2" x 3.5" pipe for the offset pieces
(1) 1/2" x 3.5" pipe for the center section.
Build this first to get all the measurements needed for the other parts. Put all the part together as shown in the picture. Tighten them very tight, but make sure everything is squared up and the bolt patterns of the flanges are square. I primarily used black pipe parts because I found some around. To prevent the parts from loosening later, I tack welded them, but I am sure epoxy or JB Weld would do. Measure the offset the pedal shafts have from the center. This will be used for the bolt patterns on the wheels later. Measure the width of the clear areas of the pipes in the pedal area for the widths of the pedals.
4 comments
Apr 24, 2009. 12:05 PMsibblyman541 says:
where did you get those parts???
Apr 28, 2009. 10:17 PMTechNerd1012 says:
could you also just get normal silver pipe and paint it black?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
92
Author:bdring
