3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Steampunk Style Fan
Step 2Assemble the Fan Parts
First, I removed the motor housing from the fan's original base. I removed the screws holding the housing together, and pulled out the broken armature. I'll be using a steel rod of the same diameter in its place. I would have just used the original armature shaft, but it was broken off too short.
I put the housing back together, and inserted a threaded rod (available at hardware stores) into the bottom of the housing in the hole where the pivot was.
I cut out a section of the brass sprayer that I planned to use as the neck of the fan, and cleaned up the cast iron lamp base I planned to use. I polished up the brass parts with a bench mounted buffing wheel, but you can use brasso or another polish - just takes longer.
Then, I put everything together to test fit it. The threaded rod passes through the brass tube of the sprayer and the cast iron base. I put on a washer and nut beneath the base to hold everything together nicely.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
8
Author:reluctant_paladin
