Steampunk USB Flash Drive
 by Kaelessin
Contest WinnerFeatured
"And as they stared in wonder at the glowing box the small device off to their left began to whirr and behold! a luminescence began to grow and fade rythmically while the box's images flashed and changed."
I've been away for a while but I haven't been idle! Here's the first of a few new Instructables on their way!
As an applications developer you can imagine that I do a lot of transferring data. Home to work and back, out from behind firewalls and back etc. I also need to store my own applications that I've developed an of course my writing so that when over at the folks' or friends' houses and an idea strikes I can immediately write it down or use my little tools! So you get it . . . I utilize these little drives extensively but, as usual, I was not pleased with their out of the box look . . .from the branding all over them, to the distinctly modern look, right on down to the mere fact that they are encased in plastic . . . ugh!
Solution: pry them out of their boring little cases and create something worthy of the high profile data stored within! Read on to discover how I applied my love of tinkering and the steampunk aesthetic to a more ordinary device than previous projects!
Step 1: Gather Materials and Tools
"The bench, old and weathered and cracked, stood resolutely in its place. Upon its wizened surface were carefully placed, an array of tools and materials, the fading light glinting off of their metallic faces. They waited with patience for the morrow upon which their crafter would return to his work"
For this project you'll be needing the following materials (some of these are optional depending on your design decisions):
* USB Flash Memory Drive - available nearly everywhere these days
* Length of Copper Pipe (The diameter depends on how wide the circuit board on your drive is. I used 3/4"
* Variety of sizes of brass tubing
* Hot glue
* JB Weld or JB Quick (if this isn't available near you then some sort of strong 2 part epoxy)
* Silver soldier
* Jeweler's flux
* Silver banding (used for making bezels)
* An assortment of brass and steel watch parts
* Metal polish (I used silver polish)
As well as the following tools:
* A vise
* A hammer
* A torch (if you will be soldiering anything to the case - i used oxygen/propane)
* Needle nose pliers
* Pipe cutter for small diameter pipe (a saw will work too but the cutter provides a nice perpendicular cut!)
* Jeweler's saw and several blades
* Spring loaded Center punch (doesn't have to be spring loaded but it helps immensely)
* Drill with various bits
* Fine files
* Sandpaper in varying grits (100, 600, 1200, 8K)
* Hot glue gun
Of course this list is either too extensive or incomplete depending on what sorts of things you wish to do to create your case. This is just a list of what I used to create mine.
Obviously one does not have to use brass tubing, copper piping, and watch parts . . .you could do it with steel pipe, brass tube and old computer parts for a more dystopian/cyberpunk look as well . . .it's entirely up to you!
Part of the fun with the whole steampunk aesthetic is the creativity possible within it's somewhat loose boundaries!  I am a writer at heart and with luck will be so by profession sometime soon so for me a lot of the fun is derived in creating a background story for each piece. I imagine workshops and a world gone awry and provide little tidbits of this story as intros for each step. I feel that it gives my pieces a figurative weight which is enjoyable! This is an opportunity to express oneself and create something truly personal and wonderful! Leap at the chance!
Read on for instructions of the actual build!
prototype2213 says: Jun 23, 2010. 10:02 PM
Finally a good Instructable on how to make a Steampunk USB case. I've searched for the last few weeks and have only found slideshows that don't provide enough detail. Thanks for posting this. It's going to be my summer project along with some goggles.
rocketsurgery says: Jun 23, 2010. 11:15 PM
Absolutely love it... steampunk can be done well and this is such an example... I'll have to see what bits and pieces I can find locally and try it out... I love the gears... has anyone tried running a micro motor (or a mobile's vibrator motor) to make the gears spin and whir? Now that would be cool! I especially like the quotes (did you write them? or are they from a book - very poetic either way)... Thanks for the instructable.
Kaelessin (author) in reply to prototype2213Jun 23, 2010. 11:15 PM
Awesome! I can't wait to see them! be sure to post the results
Kaelessin (author) in reply to rocketsurgeryJun 24, 2010. 7:34 AM
Moving parts would be wicked cool . . . *muses* I would imagine that if one made the initial casing longer and left room for a motor they could use the power from the computer coming in through the usb port (splice in a couple of wires?) to run a small motor which could indeed spin the gears while it's plugged in . . .that's a REALLY cool idea! I did indeed write the quotes . . . I just made them up on the spot for each step (heh so THAT's why they're so applicable lol). I started doing that a couple ibles ago and have fun with it so I'm going to keep it up :D some day i'll be putting more than a couple of those kinds of things together and calling them books but for now I'm winning the bread by programming computers Glad you like the ible and the quotes too!
rocketsurgery in reply to KaelessinJun 24, 2010. 8:19 AM
If you switched the motor to run only when the disk is being accessed (ie when the led is on) then the faint whir of gears would be present just every now and then... I'll have to give it a try... the quotes are a lot of fun and they really tie the room together (so to speak)... booker prize here you come ... again... great 'ible!
paperclip32 in reply to KaelessinJun 24, 2010. 1:56 PM
You used one of those slide-y type right?I'm sure you could make some sort of motor that retracted the USB once power was cut off.Might take alot of programming and a really,really tiny motor,but it's possible.
prototype2213 in reply to KaelessinJun 24, 2010. 3:11 PM
I will. Thanks again for the Instuctable and good luck on future creations.
Kaelessin (author) in reply to paperclip32Jun 24, 2010. 3:25 PM
yep initially it was the slidey kind but after removing all the case components it's really just like every other one. It's definitely possible . . .size is negotiable too since you can always make the case bigger . . .after a certain point pockets aren't good containers any more
drewgrey says: Jun 27, 2010. 7:51 PM
I saw a steampunk exhibit in oxford last year at the history of science museum. It was brilliant. I love the reinfusion of art into soulless technology.
Kaelessin (author) in reply to drewgreyJun 28, 2010. 9:04 AM
"reinfusuion of art into soulless technology" <-- love it! Heh I wish i could see an exhibit like that! shoot . . .I merely wish i could be in Oxford!
drewgrey in reply to KaelessinJun 28, 2010. 9:19 PM
http://www.mhs.ox.ac.uk/steampunk/album/?album=1&gallery=9 will take you to the photos of the exhibit. Also check out the scientific instruments! Drew
doozer_not_fraggle says: Jul 1, 2010. 7:31 AM
Totally great piece....LOVE it....love the tubes, and the working LED. I feel like Sherlock Holmes was once challenged by the guy who owned that USB key! Great piece, and great instructable!!!! Fun way for us to get into the 'punking scene!
Kaelessin (author) in reply to doozer_not_fraggleJul 1, 2010. 9:20 AM
what you don't know is that my nickname among my colleagues at the university has been simply "M" Thanks for the comment! Post some of your creations for the betterment of the scene!
or_ford98 says: Jan 28, 2012. 9:11 PM
what's with the ancient quotes? O.o uber cool 'ible tho :)
Kaelessin (author) in reply to or_ford98Jan 28, 2012. 10:27 PM
haha actually they're only as old as the ible . . .i wrote them in there for ambience *shrugs
glad you liked it though :D
jwilson44 says: Aug 8, 2011. 10:06 PM
wow looks fantastic. Couple questions though since I've never done anything like this before:
1. A Jeweler's saw. Is it absolutely necessary? If so, where can I find one, and how much will it run me?
2. In your opinion, would it be possible to avoid using glues? One of the reasons I love steampunk so much is that it's mostly metal. A lack of hot glue/epoxies would make this a lot better for me.
Thanks!
Kaelessin (author) in reply to jwilson44Aug 9, 2011. 7:56 AM
Thanks for the comments and questions!
I would imagine you could get away without the saw but in reality it's probably the easiest way to cut the various pieces. The frames cost anywhere from 8-25 USD or so depending on how nice you want to go. The blades are cheap ... sold by the gross (144). They're for sale at jewelry supply stores (there's one or two huge ones in most major cities) or failing that they may be bought online.
As for glues: yes and no. You could solder everything except the last part (the end cap). There may be a different way than glue to do this last piece but I'm not sure. perhaps you could even make the cap removable so the casing could be used on different drives (in the event one goes bad on you or something) with a movable way to lock it in. You definitely can't soldier it though because the heat would surely kill the plastic and delicately soldered wiring of the drive.
I hope that's sufficient! Let me know if you have any more. Welcome to instructables by the way!
dropjohn says: Aug 2, 2011. 8:28 AM
really nice detailed instructable - good work!
thanks immensely for sharing.
Kaelessin (author) in reply to dropjohnAug 6, 2011. 10:45 AM
not a problem! I'm glad you enjoyed it!
rammstein2 says: May 25, 2011. 12:47 PM
it would be more than badass if the gears whirred during data transfer.. ;-)
Kaelessin (author) in reply to rammstein2May 25, 2011. 4:06 PM
agreed :D
acosicris says: Jan 18, 2011. 6:05 PM
Nice one. I wanted to mod my flash drive too but I don't have a damage hard drive. I guess I have to wait until it is broken. =)
Kaelessin (author) in reply to acosicrisJan 26, 2011. 3:36 PM
Patience is a virtue indeed but should you run short on it you can find bits and pieces of watches and whatnot on ebay and other internet merchents.
cblazzer in reply to KaelessinMar 25, 2011. 11:10 AM
I sell WATCH PARTS and many other STEAMPUNK items (brass keys, wings etc) in my eBay store.
Here's a link to the watch parts.
http://cgi.ebay.com/29g-Sale-Lot-Steampunk-Vintage-Watch-Parts-Altered-Art-/130420346565?pt=LH_DefaultDomain_0&hash=item1e5da88ec5
Let me know if you'd like to link your website to my store for people to find more steapmunk items.
Thanks,
Carolyn
cblazzer says: Mar 25, 2011. 10:50 AM
Here's a great place to get the WATCH PARTS: http://cgi.ebay.com/29g-Sale-Lot-Steampunk-Vintage-Watch-Parts-Altered-Art-/130420346565?pt=LH_DefaultDomain_0&hash=item1e5da88ec5
Hope that helps.
The_Warlock says: Mar 24, 2011. 1:12 PM
I llike the writing bit... gotta try it someday....
MurphyHarris says: Mar 18, 2011. 7:40 AM
what is that blue sticky point for one.
Kaelessin (author) in reply to MurphyHarrisMar 21, 2011. 10:28 AM
I'm not 100% sure what you're asking but i'll give it a go:
There are 2 blue things in the photo:
* one is a pipe cutter (squarish blue metal tool with a triangular notch and a wheel)
* the other in a tube is 2 part epoxy putty. You cut a bit off and mix it up with your fingers like clay and it will stick things together or allow you to create shapes that cure very hard.
MurphyHarris in reply to KaelessinMar 23, 2011. 7:40 PM
ah ok - im talkin about the epoxy putty
MurphyHarris says: Mar 18, 2011. 7:38 AM
what to say. look like it should. good work. where is the cap? 4stars
mohsen_sam says: Oct 13, 2010. 2:29 PM
i love it
Lorenzo77124 says: Jul 1, 2010. 7:41 AM
Great job! Congratulations and thanks for this. It will be a great present for my father. ;-) See you!
Kaelessin (author) in reply to Lorenzo77124Jul 1, 2010. 9:21 AM
I know I would be thrilled to receive something like this but then I'm a bit of a nut for cogs and metals ;)
mibz man in reply to KaelessinAug 28, 2010. 8:40 AM
te he. 'nut' for cogs and metals. te he
Kaelessin (author) in reply to mibz manAug 29, 2010. 8:24 PM
exactly! finally someone who gets my humor! most people usually (te hee hee) BOLT!
mibz man in reply to KaelessinSep 10, 2010. 4:09 PM
ok now ur pushing it.
-chase- says: Jul 1, 2010. 8:56 AM
Ditto on it looks great - nice job punkin it out. - love to see a cap for the usb end and then it'd look good enough to serve a dual purpose - as a usb flash drive and a cool looking punked out necklace charm - heck i'd wear it. ;0) again - great job Kaelessin
Kaelessin (author) in reply to -chase-Jul 1, 2010. 9:25 AM
ooh . . .a necklace . . .good idea! I don't really wear jewelry (aside from a watch) so i never thought of this but perhaps my next one will be a necklace! I hope to be able to make and sell these (and similar) things some day and I would imagine necklaces would be popular!
prototype2213 in reply to KaelessinAug 27, 2010. 1:45 PM
Why don't you try Steampunking your watch. Hopefully, I'll post an Istructable on a Steampunk watch soon (when I have time, and a watch).
Kaelessin (author) in reply to prototype2213Aug 29, 2010. 8:22 PM
I have to keep a somewhat professional exterior right now since I'm in the consulting business but definitely a project for a time when I get a new one! (heh with a watch you always have the time! (get it!!??))
prototype2213 in reply to KaelessinAug 30, 2010. 8:19 PM
That's a timeless joke (I'm sorry, that was bad). It could make a great gift for someone. Keep up the great Instructables!
zombiefire says: Jul 30, 2010. 8:00 PM
you spelt solder wrong
Fretless says: Jul 29, 2010. 2:18 PM
Steampunk is ftw.
Kaelessin (author) in reply to FretlessJul 29, 2010. 2:39 PM
It most absolutely is. *adjusts monocle*
Fretless in reply to KaelessinJul 29, 2010. 3:06 PM
if i had the time and money id have a full steampunk get up. im going to college for digital electronic tech and robotics so when i have money i plan on making myself some cool steampunk stuff.
Kaelessin (author) in reply to FretlessJul 29, 2010. 9:13 PM
I just published another ible that cost me literally nothing . . .with the right resourcefulness you can scrounge quite a lot!
Fretless in reply to KaelessinJul 30, 2010. 8:14 AM
wel the problem is i just moved so i really dont have anything i can tinker around with i own a computer some clothes and my instruments. and about 1023495827345 soldering irons.
Kaelessin (author) in reply to FretlessJul 30, 2010. 10:14 AM
aww, well, you will surely find random bits lying around soon enough eh?
Fretless in reply to KaelessinJul 30, 2010. 1:45 PM
Yeah :) i'm sure I will
shveet says: Jun 25, 2010. 1:42 PM
That's pretty sweet, you should add a cap for it, have a female usb as the cap and build around it, i think that would be sweet. (id make one but I'm currently out of spare usb sticks) again good job.
Kaelessin (author) in reply to shveetJan 7, 2013. 10:33 AM
that was the plan initially but i, unfortunately, do not have any female USB bits lying around. I'll get around to it at some point I'm sure.
Minato134 in reply to KaelessinJul 29, 2010. 8:07 AM
CAN YOU JUST LEAVE A HOLE FOR THE FEMALE USB AND SHOW US HOW TO MAKE A COVER PLEASSSSSSSSSSSSEEEEEEEEEEEEE!!!!!
Kaelessin (author) in reply to Minato134Jul 29, 2010. 8:57 AM
whoo . . .loud! lol just messing with you. It is hard to read all caps though.
I'm working on an entry to the Flashlight contest right now but will put something together when I've a chance. Subscribe to me and you'll be sure to see it when it comes out!
corey_caffeine in reply to KaelessinJun 26, 2010. 4:23 AM
that's probably for the best, if they reproduce in an unsupervised environment then we would run the risk of overpopulation
Kaelessin (author) in reply to corey_caffeineJun 27, 2010. 12:57 PM
Not to mention we know how unscrupulous these little things can be . . .we'd have a veritable epidemic of FSTDs (File Sharing Transmitted Diseases). ;)
corey_caffeine in reply to KaelessinJul 3, 2010. 5:09 PM
indeed *adjusts monocle*
whiplash18 says: Jul 21, 2010. 6:55 PM
hey how much would you sell that for? or if ur not selling that one, could u make one for me? That is soooooo cool! U did a great job and this is a great instructable!
Kaelessin (author) in reply to whiplash18Jul 22, 2010. 1:47 PM
I've sent you a message in reply to yours but for the benefit of those reading this: I'm going to be opening a website soon to sell "Steampunk Artifacts" and these will be one of the many things offered. At the moment I haven't begun anything like this yet but if enough people show interest I may be able to offer these affordably. Look for the site in a month or two. If you are desperate for me to make somthing then message me and we can work out the details.
Blubber300 says: Jul 20, 2010. 10:56 PM
:O That looks AWESOME!! Great job!!
lazer155 says: Jul 16, 2010. 3:16 PM
What size brass rod did you use?
Kaelessin (author) in reply to lazer155Jul 16, 2010. 3:31 PM
I actually used three different sizes of brass tubing . . .the actual measurements are not very important here (I don't have them on hand but if you really need them I'll look them up) just choose what fits with your design aesthetically. It is, however, important that you use tubing and not rods if you are attempting to create the port hole that the led shines through. I bought mine as an assorted pack from a company called micromark (check them out to see if they ship to your area). they also sell quite a variety of tiny tools, tiny parts, tiny. . .well . . .everything lol. There are also many other online stores more dedicated to selling brass pipes and tubing.
geekdude says: Jul 5, 2010. 8:49 PM
I think it would be cool if the plug was made of brass or copper or at least looked like it was. copper probably has better electrical qualities. Idk how you would do that though because I dont think you could find a plug like that, and it you just paint it that would lower its conductivity.its almost like you would have to make a plug yourself. The pins are probably copper, or gold plated. all you would need to do is replace the shield and the red plastic. Im thinking wood would work well for the plastic. you would have to make it to exactly the right size or it would never fit in the plug.
Kaelessin (author) in reply to geekdudeJul 5, 2010. 10:19 PM
hmmm that does sound very intriguing! . . .i'm pretty sure the metal enclosure doesn't do any of the data transfer so it should be replacable with no issues . . .one may even be able to find some kind of patina to do the trick. Thanks for the input!
waterbaby in reply to KaelessinJul 9, 2010. 11:40 AM
How about a copper-colored permanent marker? Wouldn't add any dimension and shouldn't rub off...at least not for a long time, and easily reapplied if it did.
Kaelessin (author) in reply to waterbabyJul 9, 2010. 3:51 PM
that'd be cool but i really enjoy working with the copper and tools and that. thanks for the suggestion!
ymnhefty says: Jul 6, 2010. 7:09 AM
You should steampunk your car remote too. :-)
Kaelessin (author) in reply to ymnheftyJul 6, 2010. 7:41 AM
...why didn't I think of that before!!! brilliant idea!
BunnyMacSteam says: Jul 5, 2010. 5:55 AM
its a verry nice one , but if you have all these chainweels and you have a usb that can move why didn't you make it that if you scrolled over a chainweel the usb part would slip out of its case ??? that would be super steampunkish :p (its only an idea ha :p ) greetz
Kaelessin (author) in reply to BunnyMacSteamJul 5, 2010. 10:20 PM
there's actually one been made that does precisely that . . .I'll think about that sort of thing for a future project . . .this was the first time I'd tried anything like this so I wanted to keep it somewhat simple
Aryo DN says: Jul 4, 2010. 6:57 PM
great...
wanamoka says: Jul 2, 2010. 10:39 PM
I hope it's ok that girl's like this stuff, cause I think it is freaking awesome!
Kaelessin (author) in reply to wanamokaJul 3, 2010. 2:17 AM
haha of course it's okay! you'd probably be surprised how strong the female following of steampunk stuff is! Thanks for the compliment!!
Bugsley says: Jul 2, 2010. 5:54 AM
Great discovery, thanks.
wertyleigh says: Jul 1, 2010. 10:13 PM
What I think would top this off is if you could somehow make a cap for your USB pen :O. Great job dude. :)
axydlbaaxr says: Jul 1, 2010. 6:48 AM
Beeeeyooootiful. Excellent work.
Kaelessin (author) in reply to axydlbaaxrJul 1, 2010. 9:30 AM
:D
axydlbaaxr in reply to KaelessinJul 1, 2010. 1:28 PM
I want to vote for this, but am not smart enough to find a "vote" button. Damn me.
Kaelessin (author) in reply to axydlbaaxrJul 1, 2010. 2:35 PM
hey no worries it's not a smart problem :) The contest is structured in such a way that the vote button doesn't show up yet. They're accepting entries until the 4th and voting begins on the 5th. be sure to come back on the 5th and vote! Thanks for the support!
Davesp says: Jul 1, 2010. 1:01 PM
You mention of runes at some point set me thinking and after a few nano seconds of it (thoughts) I came up with the rune marked resin/stone USB case (R) for an Irish audience.... The runes seem appropriate for a USB drive (they are no more than an almost binary system anyways).... But do you think a USB innards could take being embedded in resin???
Kaelessin (author) in reply to DavespJul 1, 2010. 1:18 PM
Since these little drives work off of flash memory they do not generate much (if any) heat so as long as your resin doesn't react with the silicone, plastic, metals, etc. you should be fine. I've seen these dunked in resins before and heard no complaints . . .I'd love to see the result when you're done!
Crucio says: Jul 1, 2010. 8:36 AM
A very handsome piece, Kaelessin. Congratulations. I enjoyed reading the little quotes at each step. What are they from?
Kaelessin (author) in reply to CrucioJul 1, 2010. 9:23 AM
Very happy that you think so! *takes a bow* The quotes are actually not really quotes per se . . . I am a writer and so for this (and some of my other) instructables I enjoy writing little tidbits to give a bit of figurative depth to the instructable as if there is some larger story to be read. If I get the opportunity I am sure they will be a springboard for a full fledged novel. I am very glad that you like them!
Crucio in reply to KaelessinJul 1, 2010. 10:08 AM
Extra kudos, then. Reading them took me somewhere else momentarily. You have the talent to capture the reader's attention. Best of luck on the novel.
brichins says: Jul 1, 2010. 9:25 AM
My first thought was "oh, I hope the gears spin!" I assumed they wouldn't :( However, I think it would be pretty easy to add a tiny motor from a usb powered fan and mount a gear instead of the fan blade. Some sort of guard, either around the edges or a plexiglass cover, would be in order. I would love to see someone do this - please make an 'ible and message me when it's done!
Kaelessin (author) in reply to brichinsJul 1, 2010. 9:39 AM
I'm sure I will sometime! Right now I'm doing a few other things but am confident that I'll get around to doing that soon :)
d0rkyg1rl says: Jul 1, 2010. 9:29 AM
I need to get my hands on some watch parts because I really want to do this project ^-^ Your finished product looks amazing and your instructions were very clear. Thank you for posting them!!
Kaelessin (author) in reply to d0rkyg1rlJul 1, 2010. 9:32 AM
You can check out antique stores, thrift shops, flea markets or the old trusted favorite of mine ebay lol. Thanks for the compliments! I guess my training in technical writing has paid off! If only my former employer knew their dollars were going to my hobbies lol
d0rkyg1rl says: Jul 1, 2010. 9:16 AM
I know you might not have put it on the list of tools because it's so automatic for you but for those who've never done this stuff because you forgot to say some sort of lube for the drill bits and saw blades if you're going to be cutting the metal with them. I use bee's wax but lip balm or a white wax candle will work too. Lubing the blades and bits before using them will prolong their live and make drilling or sawing much easier.
Kaelessin (author) in reply to d0rkyg1rlJul 1, 2010. 9:29 AM
this is true! thanks for the tip. I actually didn't think to use lube and will make that edit after this weekend hopefully.
Green Silver says: Jul 1, 2010. 9:16 AM
Looks good, but I can imagine the small gears snagging in your pocket.
Kaelessin (author) in reply to Green SilverJul 1, 2010. 9:28 AM
Thanks! @ the snagging: indeed! and at first they did. tore a couple off initially which was sad but I solved the problem by adding a bit of epoxy around their edges and though it's not visible they're protected now!
Car6on14 says: Jul 1, 2010. 8:25 AM
looks great, love the gears... now I have a use for the old mechanical watch I tossed in my box of stuff to use for future projects!
baneat says: Jun 26, 2010. 11:43 AM
How awesome would it be if the cogs actually worked! I'm sure it's possible, the electrical energy taht should go the LED on many flash drives could instead be used to power a very small motor, which could turn a cog and consequently smaller ones. It takes surprisingly little to power my clockwork watch.
TSC says: Jun 25, 2010. 3:08 PM
Cool!!!!!!!!!!!!
absolute zero says: Jun 23, 2010. 1:57 PM
AMAZING!!! in part 2 of step 4 you may want to change "soldier" or "solder" :P
Kaelessin (author) in reply to absolute zeroJun 23, 2010. 11:17 PM
oops! thanks for looking out for that! If I fix it does it lose the "featured" status when I post?
scraptopower in reply to KaelessinJun 24, 2010. 1:17 AM
Thanks!, the vote buttons don't appear until the 4th of july I think, but when they do they'll be on the top of any entry.
absolute zero in reply to scraptopowerJun 24, 2010. 7:34 AM
okey dokey then, ill be sure to vote for this!
Kaelessin (author) in reply to absolute zeroJun 24, 2010. 5:35 PM
much appreciated!
nickodemus says: Jun 24, 2010. 1:46 PM
Beautiful! :D
tiekietemboe says: Jun 24, 2010. 12:14 PM
yeah, pretty mad!!!
Vinterdragen says: Jun 24, 2010. 9:11 AM
Thanks mate!, Awsome Instructable
kcls says: Jun 24, 2010. 5:38 AM
That is really cool looking! Great 'ible, very descriptive.
Kaelessin (author) in reply to kclsJun 24, 2010. 7:34 AM
:D
scraptopower says: Jun 23, 2010. 3:06 PM
I'd have one of these! You've got my vote!
absolute zero in reply to scraptopowerJun 23, 2010. 3:33 PM
ive never actually voted for anything, but if you would guide me to the vote button, wherever it may be, i will gladly add to yours.
Thanks to you both! I don't believe the voting has begun yet but if you like it then please rate it! cheers!
Ausm says: Jun 23, 2010. 5:23 PM
I don't know if it's just me, but I get a 500 server error when I try to access the second step.
Kaelessin (author) in reply to AusmJun 23, 2010. 11:16 PM
hmm that's strange. . .I think it may be just you unless I'm lucky with a couple different computers. If it keeps up i suppose you could log a bug report.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
