Steampunk USB Stick "Speichergeraet Nummer 1" by thechocolatist
Featured
I send you greetings from Helvetia, a small country in Europe with the World's Best Chocolates.
People call me "The Chocolatist" and I'm a creativ Steampunk. Visit me on www.thechocolatist.com.
This time I present you a really simple "instructable" to create your own "Steampunk USB Stick". Again it's one of my Micro-Projects which you should be able to finish within 60 minutes.
Step 1: What you need
First a short list what you need for this project. Use your fantasy which parts could fit to your project.
Whit this instructable I would like to give you an inspriration how you could build a simple USB Stick in less than one hour.
- an old brass bearing from an old machine
- a broken tube from an old car radio
- a cheap USB memory stick
- copper wire
...and if you want to finish the project in 60 minutes you will need a Hot Glue Gun. Not so really "steampunky", but the only way to make it simple and fast.
If you want to do it perfect, you have to solder the tube to the brass bearing and you have to cut a brass plate to mount the memory stick.
nerd7473 says: Apr 11, 2013. 2:05 PM
wow cool
hwaranghaw says: Mar 12, 2012. 6:55 PM
Ingenious! very hipster too!
Machine says: Mar 10, 2012. 2:59 AM
Hey, that is cool. Nice steampunk device. Clever that there's a LED to light up in the vacuum tube.
Junophor says: Mar 9, 2012. 6:34 AM
Take a bow Maestro!!!
Great work and this a patch worth;-))))
Cheers Aeon Junophor
Admiral Aaron Ravensdale says: Mar 8, 2012. 12:39 PM
Very nice with a clean and simpl structure. I like it!
Horatius.Steam says: Mar 8, 2012. 7:22 AM
Great work :-)
thechocolatist (author) says: Mar 7, 2012. 9:56 PM
Hi - Thanks for your comment - yes, the LED is under the tube and light up the tube when the memory is running.
Winged Fist says: Mar 7, 2012. 2:40 PM
What a great looking steampunk USB! Does the LED from the USB light up the tube? Thanks for sharing!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
