Steampunk USB Stick "Speichergeraet Nummer 1"
20,723
144
10
Posted
Introduction: Steampunk USB Stick "Speichergeraet Nummer 1"
I send you greetings from Helvetia, a small country in Europe with the World's Best Chocolates.
People call me "The Chocolatist" and I'm a creativ Steampunk. Visit me on www.thechocolatist.com.
This time I present you a really simple "instructable" to create your own "Steampunk USB Stick". Again it's one of my Micro-Projects which you should be able to finish within 60 minutes.
Step 1: What You Need
First a short list what you need for this project. Use your fantasy which parts could fit to your project.
Whit this instructable I would like to give you an inspriration how you could build a simple USB Stick in less than one hour.
- an old brass bearing from an old machine
- a broken tube from an old car radio
- a cheap USB memory stick
- copper wire
...and if you want to finish the project in 60 minutes you will need a Hot Glue Gun. Not so really "steampunky", but the only way to make it simple and fast.
If you want to do it perfect, you have to solder the tube to the brass bearing and you have to cut a brass plate to mount the memory stick.
Step 2: How to Do It the Simple Way
If you decide to go the simple way and you want to finish a nice Steampunk USB Device in less than 60 minutes - then let me give you some advice:
- strip the plastic from the USB Memory Stick and clean it with an alcohol
- check the position of the LED - maybe you can bend it towards the tube for a better light effect
- put the tube on the brass socket and fix it with tape. Be sure that there is no gap between the glass and the brass socket
- heat up the hot glue and fill it into the brass bearing. When the glue is cold you can take off the tape
- place the memory stick into the bearing and fix it with tape
- fill up with hot glue just to the top and wait until the glue becomes hard
- now use copper wire to create some nice style and clean up your work
That's it.
Sorry that I don't have some more pictures, but I didn't plan to write an instructable about this small project.
Next time I will have the camera with me......
Hope I could give you some ideas for your own simple USB Device.
Sincerely yours
"The Chocolatist"
    • Spotless Contest
      Spotless Contest
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    10 Comments
    OUt of curiousity, how did you add that wire/handle on the side of the bushing, was that soldered on?
    Hi. Thanks for your interest. I drilled two small holes into the brass tube and used a hammer to put in the small handle, made out of steel. The handle I shaped a little but too small, so it stucks very good in the brass..... forever :-)
    Ingenious! very hipster too!
    Hey, that is cool. Nice steampunk device. Clever that there's a LED to light up in the vacuum tube.
    Take a bow Maestro!!!
    Great work and this a patch worth;-))))
    Cheers Aeon Junophor
    Hi - Thanks for your comment - yes, the LED is under the tube and light up the tube when the memory is running.
    What a great looking steampunk USB! Does the LED from the USB light up the tube? Thanks for sharing!
