3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Wood Veneer Laptop Mod
This is my first Instructable YAY! In this Instructable I will show you how to apply a wood veneer finish to your laptop to achieve an old school look to modern tech.
Disclaimer: I'm not responsable for any permanent damgage to your laptop, if you don't want to permanently change your laptop than this is not for you.... this is not reversable. Be sure to take proper percaution when using liquids near laptop.
Step 1Materials
Materials
The materials you will need for this project:
1) Laptop
2) A sheet of wood veneer(you can pick this up at most hardware stores like home depot)
3) Gold paint( if you can disassemble your laptop safely then use spray paint to give an extra shinny smooth look, I simply used a gold paint pen, I tried many different paints including enamels and acrylics,but they all chipped too easily... but the paint pen held up well. use a plastic primmer if possible(any tips you could leave me in the comment section of better ideas would be appreciated))
4) Brass wire(for edging)
5) Misc. ornamental jewelery(for decorating the top)
6) Paper(for tracing design)
7) Xacto knife
8) Super glue
9) Masking tape
10) Wood stain (i used cherry)
11) Polyurethane
12) Double-sided heavy duty adhesive sheet
Helpful Links:
flink Suggests:
"When choosing wood veneer, please be aware that there are different types of veneer as well as different wood species. Veneer can be found unbacked, paper-backed, and adhesive backed.
Make certain you have the right type. Needless to say, adhesive backed is what you should use here unless you have experience with contact cements :-)
Some sources of decent veneer:
www.rockler.com
www.woodcraft.com
The borgs have veneer, but seldom have a wide selection. From Rockler or woodcraft you can get some really exotic stuff. Some real lumberyards have veneer, too. Typically those that carry a good selectino of hardwoods.
You could also try
www.woodfinder.com to search for a veneer supplier in the US or Canada."
And heres a good link for hardware suggested by XaqFixx: Whitechapel, ltd.
81 comments
1-40 of 81next »
Feb 23, 2012. 6:40 PMWinged Fist says:
This is a really incredible laptop mod! Also a fantastic first instructable!
I'm curious; Now that it's been a few years since you made it, how has the wood veneer held up? I'm thinking about a similar laptop mod, and debating between veneer and contact paper. I'm sure veneer would look nicer, but I'm concerned that it might crack, split or chip with everyday use.
Any chance of seeing a photo of this after a few years wear-and-tear?
Sep 27, 2011. 7:03 PMMattosaurusRex says:
I just found an old iBook from 2001, think it needs a wood veneer! Thanks for the Ible!
Feb 9, 2010. 1:08 PMPugofstardock says:
This is great!
Did this with my Toshiba a few days ago but with a  plastic wood-lookalike-foil.
it looks like wood but is easier to apply and cheaper.
had it at work yesterday and my (female) coworkers were impressed. ;-)
May 8, 2011. 10:39 AMPugofstardock says:
in reply of my own comment
heres a pic of the laptop
Aug 19, 2010. 10:12 AMs1dh says:
THIS is an awesome tunning operation , CONGRATULATIONS !! I would like to have a feedback about Wireless : did you notice wireless reception decrease performance ? (As the antenna of your wireless NIC is behind the LCD screen , the back of your screen act as a receiver. If you add wood on this side the wireless signal could be lower ...)
Jul 27, 2010. 6:05 PMtuckerton296 says:
thanks, youve given me the idea for the faceplate on my tower
Jul 25, 2010. 3:01 PMthinkpadt30 says:
Extremely professional-looking job! It looks like a high-end custom laptop done for a celebrity or a CEO. Pat yourself on the back!
Jul 24, 2010. 8:28 AMmartzsam says:
Something you should try is Krylon plastic adhesive spray paint. It actually bonds with the plastic so it won't come off. Anyway, nice work! I really like the cherry finish. This is quality work. Keep it up! Sam
Oct 8, 2009. 5:13 AMmsw3113 says:
Is that an 8500?  Nice result, well done.  Work to be proud of.
What's next?  Veneered iPhone?
Jul 19, 2010. 12:48 PMsqeeek says:
LOL exactly why I don't have one :D Great instructable btw, thinking about using this on one of my old laptops... I have an Inspiron 1100, and a Tecra S2...
Jul 19, 2010. 12:30 PMsqeeek says:
Nice one, I might have to try that. I'm looking for a way to make this old Inspiron 1100 I just got look a bit better...
Jul 19, 2010. 12:26 PMsqeeek says:
Actually, I don't think water would hurt much of it. The screen, maybe, but usually electronics can handle plain water pretty well. My dad and I have a family network business, and we've soaked a couple of routers in saltwater before to short out and therefore reset the FLASH memory, and they have always worked just fine afterwards :D... don't recommend that, though, unless you have to.
Mar 8, 2010. 7:45 AMlinc5885 says:
This is an awesome masterpiece, I will be 100% doing this!!!, I have been staring at my old dell laptop trying to figure out how to make it look like an old Book you just showed me how sweet , Thank you for shareing.
Feb 27, 2010. 8:36 AMIrritable_Badger says:
If you have the ability to disassemble the case on the laptop any errors in the veneering process can easily be undone by using Hide Glue instead of a PVA type glue or epoxy.
Hide Glue (the synthetic stuff from Tite-Bond works as well as traditional hide glue) is used by instrument makers because a little bit of steam releases the glue so that any errors can be corrected.
If you apply the veneer and it doesn't come out correctly simple take an iron and on the low setting (no steam) and "iron" the veneer until the glue softens and the veneer will slide right off. If you are careful you can even reuse the veneer.
Jan 29, 2010. 2:09 PMLawlz Its Kyle says:
I tried this but I failed miserably. :(
Nov 4, 2009. 9:02 PMhinoai says:
Very cool! A less time-consuming (but less impressive) possibility would be to try it with wood-grain contact paper, maybe? When my laptop comes back from the shop, I'm going to give it a go!
Oct 15, 2009. 9:48 PMtrebuchet03 says:
Nice :) I woodied my laptop apparently over two years ago (the laptop isnow parts :( ) :p
Cross Link - http://www.instructables.com/id/How-to-Make-a-Woody-Laptop/
I dig your embellishments :) I wanted to do this to my EEE, but there'ssome nontrivial compound curves in parts of the case that just destroythe look when veneering. There are grander ideas peculating though :D
Oct 14, 2009. 2:09 PMhascher says:
What about using the stain that already has poly mixedin?  That might solve the issue of applying poly by itself -and you only have 1 step instead of two.  Love the look!!! Thanks for the great idea!
Oct 14, 2009. 2:14 AMBenson1 says:
I'm kind of spamming your comments but I just thought of another question....
Do you notice your laptop heating up more than usual now?
Oct 8, 2009. 6:10 AMcthiele says:
Great job for the first instructable!  The firstl look gives the impression that it's much harder to do.  What was the total price of all the pieces?
Oct 14, 2009. 2:03 AMBenson1 says:
It really all depends on the quality of veneer you get.  I know ofsome veneers that can cost up to and over 5000$......But that's veryhigh quality, and in bulk.  You can get a pretty good idea on costby looking up a local veneer place.
And the prices of stain and such vary depending on what you get.....I'mbasically answering your question by not answering your question, sorry.
Oct 14, 2009. 1:55 AMBenson1 says:
Hey, I was wondering why you would add the polyurethane after sealingthe veneer to your computer.  Wouldn't it be safer to do itbefore?  Or would the polyurethane warp the wood.....Not that itmatters....It sounds like sanding would be nicer anyways, just curious.
Oct 11, 2009. 7:27 AMRe-design says:
Nice job.  I like the fact that you didn't "recase" it.
Oct 10, 2009. 2:23 AMCurvedYellowFruit says:
Very nice! Now I'm thinking of modding my Netbook. Good ible!
Oct 8, 2009. 1:21 PMkellychap says:
This is a great idea and a great instructable.  Thanks - I'll have to see if I can conjure up the courage to do this one!
Oct 9, 2009. 3:46 AMKryptonite says:
Yeah I see what you mean, looks amazing but what happens if something goes wrong?
Oct 10, 2009. 12:30 AMKryptonite says:
I'd love to do this but trying to let my mum or dad mod one of their laptops is a near-to-zero chance.
Oct 7, 2009. 7:04 PMJCO72 says:
Sweet mod.  I'm just doin black leather and chrome on mine...
Oct 9, 2009. 3:48 AMKryptonite says:
Sounds great, post pics though!
Oct 8, 2009. 4:45 PMionfreek458 says:
 could you do this to a mac??
Oct 8, 2009. 8:14 PMconrad2468 says:
 if i get a new computer im doin it with my mac.
Oct 4, 2009. 4:06 PMTechNerd1012 says:
it seems like you could probably design this into a sleeve-like thing too, so that you can remove it if you ever needed to great instructable btw!
Oct 8, 2009. 9:13 AMWolfin says:
The only problem then would be a question of how would you keep them (top/bottom veneers) connected over the hinge.. Maybe could stitch on some fabric but that'd probably insulate the fan exhaust.
Oct 8, 2009. 5:04 PMTechNerd1012 says:
Thats true
Maybe stitch it onto some stretcy fabric, and put some kind of thin mesh (like window screens) over the fan areas
Oct 8, 2009. 8:13 PMconrad2468 says:
 thad prevent it from the emp blast.....but id suggest an old crate or a very large cigar box...
Oct 8, 2009. 4:30 PMshortone says:
 this is great! Does anyone know if/where you can get purpleheart wood veneer? Purpleheart is a tropical wood that is dark purple in color, and could look really cool on one of these...or padauk, which is almost orange!
Oct 8, 2009. 3:05 PMyyeessno says:
Remember you can/should) rub down the polyurethane with very fine steel wool between each coat. It gives a finer finish and makes it smoother to the touch.
Oct 8, 2009. 1:25 PMstatic says:
 Nicely done, all the way around, the final result looks great. But the steampunk label added to everything that looks old is getting kind of dated itself. Here the result is similar in look to Campaign furniture, that predates the steam era and deserving of attention in it's own right.
1-40 of 81next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
23
Author:DracoGT
