3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Steampunk mechanical monocle
Step 6The lens
The lens
This step shouldn't be tricky.
If you are lucky enough to find a real lens that fit, you can jump to next step without even read the next line.
Take your plastic sheet (or whatever you choose as source for your lens) and place it on your monocle. Trace the contour of the hole leaving 5 mm all around. Cut and try it. If it's too big, refine slightly the edge and try again, until you find the perfect fit. You know you have find it when the lens is only 1 mm from the edge of the hole.
If your plastic become covered with fingerprints, just wash it gently with water and hand soap.
Put it apart, avoiding to scratch or otherwise mark it.
1 comment
Jan 20, 2011. 11:19 AMmaxsuit says:
thx for telling about ur ring
lolzzz
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
6
Author:Drako84
