Step 8Elasticizing the strap
First, find the center of the strap and cut. Wear your monocle and mark and cut where the two halves meets each other. This is the length you need. Lie the monocle on a working table and hold the halves with a pin or some tape. The marks must correspond. Take one or two pieces of rubber band, depending on their size, at least 5 cm of length.
Fold 1 or 2 cm of both halves and fix them with tape. Insert one end of the rubber band in the pocket you have just formed, then do the same with the other end. Try to keep all symmetrical to better distribute the stress. When you are satisfied about your result, glue all together, paying attention on gluing the right way (the rubber band should be on the internal part, touching the head). For a stronger strap, sew the rubber band to the leather.
The strap is done. Woo-hoo!
Add Comment
