I am back again after some hard days.
This instructable is dedicated to my father in law who just had to leave us last month. Thanks to all Wolfgang and we will go on!!!
This is a three times premiere to me:
First premiere: This project had been done at one weekend
Second premiere: All parts that I used in this project had been grabbed from the bulky waste so I really haven´t paid anything for it . It is a real 100%-second hand project and the only thing I had t do was to cut two rings, one from a copper tube and one from a brass tube. It is nearly unbelievable but all other parts fit together without changing anything!!
Third premiere: I can present you two varieties of electrifying: One time I am working with my very beloved HV-flash unit from a Fujii disposal camera and the other time I use the direct power supply like a normal lamp also does.
Safety advice:
Don´t wreck your health and please obay the follwing advices:
***Disclaimers***This instructable works with voltages in excess of 250V. This is more than enough to give you a potentially fatal electric shock if handled incorrectly. If you are unfamiliar with how to work with high voltage, please refrain from performing this instructable. Exercise caution throughout the following steps to avoid electrical dangers and also use insulated tools like pliers and screwdrivers and so on.
If you choose to undertake this instructable, you do so at your own risk. (Thanks to member: the_don125)
And now let us start with this fantastic project.
Step 1: The Insulator
As you can see at the following pictures, these 1"KV pin type" insulators had been used in former times to carry power lines to the houses. Today they have been nearly all replaced and the cables are running now in the ground.
Normaly these insulators are made of electrotechnical porcelain but sometimes they were also made of glass. So I am very happy to own now nine pieces of this glass type, given by a friend of mine after replacing.
Step 2: The Neon light plasma bulb
I met a now real good friend from Alsaka. That´s the place were these rare Neon fillled bulbs are coming from. It is been said that they worked, and still work? at control panels from oilrigs. They are made very robust as you can see and they are running with 230 Volts AC but you can can drive them with a flash unit from a disposal camera too. You can see the difference at the following photos. And only this bulb type fits in the Insulators hole so many thanks to you Bill!!!.
see also: this instructable
Step 3: Constructing the bulbholder
A lot of the parts are made of brass and looked totally rotten. But polishing them a little bit with some steel wool after a short bathing in vinegar acid (please wear some rubber gloves at this step) let them shine brightly again. To protect them against oxidising again I covered them with some clear varnish for metals (in german Zappon-Lack) The antique triangle holder carried a lampshade made of glass or enameled metal at about 1900. So you see I love to work with antique materials from the victorian age as an authentic steampunk;-))) The bulbholder itself is also made of brass and insulated with white porcelain.
Now let´s see how I made it:
Step 4: Electrifying I (with 1,5 Volts flash unit)
The new switch will be placed in the screw hole at the side of the stand ann fixed with some melting glue.
Step 5: Electrifying II (with 230 Volts electrical power supply)
Use a two pole cord switch to make sure that there is no hidden electricity when the lamp is switched of. If you have to change the bulb,please switch of the lamp an best pull out the plug out before changing it is better for your own safety!!!
After fixing all contacts, please check them with a continuity tester before the first plug in.
Thanks to all for following
Yours Aeon Junophor
Visit Our Store »
Go Pro Today »
www.witthinrich.com
The guys might could help you to find them
Thanks for your rapturous applause ;-))))
It is such a good feeling to create new things from old parts....
that you like too.....
I hope this will inspire you all once again like you do it to me with your awsome objects.
electfire: Let´s see what is cominng out with your idea
longwinters: This couldn´t have been done without your support,- Thank you my friend
Winged Fist: To give the crown to this lamp I plan to wrap a textile cord (shoe lace) around the power cord as you have shown to us; very well done indeed;-)))
JKPieGuy: Let us see what is coming up to your mind with those parts you hold in your hands....
Grasshopper1221: I know there is another surprising idea raising up in your mind;-).......
And last but not least
Polerix and Chemicus: Thank you: Your wish is my command.... or so... ;-))))))))) I will try my very best.
Cheers to you all
Aeon Junophor
Here is a picture of the lamp currently - I am trying to go for something similar to the desk lamps you see in libraries (The last picture) but I am having a hard time sourcing locally the glass. I am also needing the support armature that holds the glass
Looking forward to seeing more.
The insulator also seems to be doing a good job of making that small neon test lamp look quite large.
An inspiration to all, lets hope you get editors pick!
