This new steampunk project is a crazy toy for my children. When you touch both brass contacts with your fingers the box starts to squeak. In less then one minute my children were able to play first melodies. I just produced only some terrible noise while testing first. The sound is really loud when you fix the loudspeaker with the box and makes the children (and parents as well????) laugh ;-)) There is no danger to anyone because the two brass contacts are workíng with a current less than 15 µA (see manual).
So this Steampunked-Squeaky-Squeezer might be a very funky DIY steampunk X-mas gift for your kids.
And this is the technical explanation of the secret:
Human beeings can be technical seen as high-ohmic and sensitve (see also the explaining given at the manual). The frequency changes with the electrical resistance of your body.
It depends of:
-the way you squeeze the contacts (loose or tight),
-the humidity of your skin,
-the aereal of contact.
The higher the frequence the lower the resistance and the other way round.
***Disclaimers***
This instructable involves soldering. A soldering iron becomes very hot during its use, to the point where it can cause instant second-degree burns. Exercise caution throughout the following steps to avoid burns. If you choose to undertake this instructable, you do so at your own risk.
Look a this film have fun and enjoy to create your own sounds.....uuuhhhhhhh, that squeaks so much.......
Thanks for following to all
and have a lot of fun with your new Squeaky Squeezer projects
Yours Aeon Junophor
Now it is up to YOU:
Remove these ads by
Signing UpStep 1The ready built up electronic, first impression
And if you got some experiences with soldering electronic parts together it is easily done.The costs are low and all of the electronic parts can be bought for their own without out a problem.
Instead of using the digit switch or pushbutton I soldered two wires for the new contacts as you can see at the following pictures. (test buzzer or morse version)When you install the trimmer potentiometer please choose a middle position to create the best sound to our ears. If not he dog will start to howl because the new frequencies are too high or too low to hear.
You can take any little box to keep the electronic and the power supply in but you have to take care the two new contacts are insulated.
I just left it open. The two contacts closing the circuit when touching both, are connected to TA /ex+ and TA/ex as you can see on at the picture
