Steampunked: Waterproof Flashlight
OH MY GOODNESS! MY FIRST FEATURED!! 8-30-08
I'm in a guide!! 12-23-08
I like Steampunk design style, and I already tried it on my pencil. I did this to my flashlight because i though it would be easy with its flat sides.
For this project, you need:
@ Gold, Chrome (silver), copper, and gold (brass) paint, clear coat/paint for finishing
@ One large 6v flashlight (mine is also waterproof)
@ Paper fasteners, Sharpie/permanent marker, hole punch, ruler, scissors
@ Hotglue, epoxy
@ Assorted gears, Small tube, Nut that fits on the tube, Three-way section of pipe/plastic that fits in tube, Screw that fits in three-way, copper wire, small spring
@ Small container
Please remember to rate and comment! Help me with this flashlight, it's my first important steampunk project.
Step 1Prepping
Prepping
  • last photo ←
First, we need to prep the flashlight.
Remove all of the parts (lens, battery, bulb, front, and case)
We will be modding the front and case of the falshlight only. Wrap the threads in tape, and if you want to, the button. I found out later you don't need to cover the flashlight. Preferably, paint it.
I didn't know what to do to the handle, but I had everything else though out. I decided to make the handle "fancy." Draw a design on the handle. Follow over it with hot glue, to make it stick out. If you have "puff" or "3-D" paint markers, use those instead of hot glue sp you can get a finer image.
Next you need to use your index card. Cut it to shape so the coners line up with the inside coners (er, inside the curve of the edges, etc) and hole punch out the corners. Keep this card for use later.
80 comments
1-40 of 80next »
Jul 30, 2010. 8:01 PMzombiefire says:
cool
Oct 15, 2009. 10:29 AMprobablepossible says:
Ah now, that's nice. You kept the gewgaws simple and they look like thathave some function, and just a touch of decoration.
Done good!
Oct 15, 2009. 10:58 AMprobablepossible says:
i would replace that half-screwed-in screw with a teensy knob of somesort... mostly because I know I would scratch myself on it sooner or later!
Sep 2, 2008. 8:08 AMLextone says:
Um....cool, nice job, but why don't you take it a step further and put a knife switch on it? It would really finish it off with some class and accuracy.
Sep 2, 2008. 2:41 PMLextone says:
Uh....why do you want to keep it waterproof? Are you gonna use it for scuba diving? Here is a pic of a knife switch. You can add one on for effect and keep the original sealed push button switch for powering it on. That switch is kinda hidden anyway.
Sep 20, 2009. 10:06 PMcorey_caffeine says:
he could fake it by putting a push button under the blade switch so it throws it
Dec 16, 2008. 4:22 PMcodongolev says:
throw the switch, igor....
what? it won't work? blast what am I going to do with the rioters at the door?
what did I do there and how can I do it again?
Apr 24, 2009. 2:37 AMcornflaker says:
lol I don't know but it looks cool
Apr 24, 2009. 2:16 PMcodongolev says:
((maybe two parenthases....
{{no? two squiggly parenthases?
}}now?
Aug 27, 2009. 11:35 AMDerin says:
2 commas
Aug 27, 2009. 1:32 PMcodongolev says:
I wonder...
what will this do?
Aug 27, 2009. 11:30 PMDerin says:
hi
Aug 29, 2009. 12:03 PMcodongolev says:
this is intense!
cool.
Nov 2, 2008. 4:45 PMCapinPorcupine says:
I'm 14 and I got a knife switch there only a couple bucks at radio shack and it would look great on it. p.s. great Instructable!
Sep 5, 2008. 9:37 PMalex-sharetskiy says:
you can get one of those re-loadable visa/master card cards, you have to pay like $5 a month if you have less then $1000 on it
Sep 6, 2008. 7:44 AMalex-sharetskiy says:
so you can buy stuff online
Sep 3, 2008. 2:55 PMLextone says:
ah.....gotcha....It was just a thought...carry on
Sep 1, 2008. 7:56 PMfinfan7 says:
Simultaneously excellent and lame. The front is great. The side with the tube is also pretty cool. However, being one of the early gearpunk enthusiasts I gotta say those gears are a bit pitiful. Four tiny gears that look just stuck to the side. I saw a discussion about this somewhere else. Each piece of the object should either look or be functional. It is cool but it just seems unfinished on that side.
Sep 2, 2008. 7:03 PMfinfan7 says:
Good work for a first mod. I would suggest that the gears look like they are really part of the object. Maybe slice a hole where the bell starts and insert half the gear. Then reseal with hot glue and attach a few other gears with maybe a winding rod attached. They only need to seem funtional,not be funtional. Or you could ditch the gears altogether and try a brass name plate. Something like: "Waterproof Portable Personal Light Source Unit-0001 If found return to Requisitions Officer Cowscankill."
Aug 27, 2009. 7:54 AMgsidhe says:
Love the nameplate idea. That would really push this pretty cool project up a notch.
Sep 3, 2008. 4:09 PMfinfan7 says:
Cool. Your response just gave me an idea. leave me another comment when you finish the modifications.
Jun 19, 2009. 7:00 PMring wraith159 says:
KOOOOOOOL
Apr 8, 2009. 3:44 PMSinAmos says:
Very steamy. It is actually a lot more steamy than what most people post. Good work.
Sep 2, 2008. 7:48 PMlordofthedonuts says:
Nice ! A knife switch would be a nice addition, but it wouldn't be a water proof flash light anymore...
Apr 8, 2009. 3:24 PMand7barton says:
Try "NIFE" switch - That's the original spelling.
Sep 5, 2008. 5:32 PMlordofthedonuts says:
If you don't mind buying online, try to look on eBay.
Nov 2, 2008. 8:11 PMcmanatlan says:
I have a question. What is the note-card thingy for? And where to buy spraypaint, tubes, shiny paint. Thank you.
1-40 of 80next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
213
Author:cowscankill
"Don't find the time, Make the time." - gmjhowe 16/3/2009 He inspires me.
