I'm in a guide!! 12-23-08
I like Steampunk design style, and I already tried it on my pencil. I did this to my flashlight because i though it would be easy with its flat sides.
For this project, you need:
@ Gold, Chrome (silver), copper, and gold (brass) paint, clear coat/paint for finishing
@ One large 6v flashlight (mine is also waterproof)
@ Paper fasteners, Sharpie/permanent marker, hole punch, ruler, scissors
@ Hotglue, epoxy
@ Assorted gears, Small tube, Nut that fits on the tube, Three-way section of pipe/plastic that fits in tube, Screw that fits in three-way, copper wire, small spring
@ Small container
Please remember to rate and comment! Help me with this flashlight, it's my first important steampunk project.
Remove these ads by
Signing UpStep 1Prepping
Remove all of the parts (lens, battery, bulb, front, and case)
We will be modding the front and case of the falshlight only. Wrap the threads in tape, and if you want to, the button. I found out later you don't need to cover the flashlight. Preferably, paint it.
I didn't know what to do to the handle, but I had everything else though out. I decided to make the handle "fancy." Draw a design on the handle. Follow over it with hot glue, to make it stick out. If you have "puff" or "3-D" paint markers, use those instead of hot glue sp you can get a finer image.
Next you need to use your index card. Cut it to shape so the coners line up with the inside coners (er, inside the curve of the edges, etc) and hole punch out the corners. Keep this card for use later.
Done good!
what? it won't work? blast what am I going to do with the rioters at the door?
what will this do?
