Introduction: Steampunked Nixie-tube-switch
About: I love to invent and create new things in a "steampunk styled way" working with brass, copper, vulcanized-fibre, brass gears and (ply)- wood. On one side I am fascinated in neon lights and small ele…
Hi everybody
I promised you to show in this instructable my next astonishing steampunk aparatus. It is called: "Steampunked Nixie-tube-switch"
or in german: "Junhophor-Plasma-Kraftstärkeregler".
My first instructable is an steampunk Plasma-converter. This object needs a switch-component and an telegraphing machine to send the created plasma beams around the world. So here ist comes
The switch:
Step 1: Starting With the Nixie-tube
Step 2: The Electrical Circuit
On a data sheet for this nixie-tube I found this simple circuit and I decided to build exactly this circuit.
So you can switch for your own to the different numbers of the tube and watch it.
Step 3: Here Comes the Steampunk Design
I took another brass fire hose valve as you already know it from my plasma-converter project and followed this design.
Ont the top you see the 10-step switch and in front there shines the Nixie-tube. The small screws on top only shows the position of the switch. The bigger ones stop  the crank.
Look at the pictures and follow the steps
Step 4: Inside the Valve and Bottom
As you know the nixie tube, as a special form of neon gas filled plasma bulb, only works with hogh voltage but low current.
I generate this HV with an electronic  from an flash of an disposal camera. In my other plasma projects I used the same modified electronic so I don´t want to repeat this step here again:-))
Hack It! Challenge
Hack It! Challenge
