Steel Pipe Air Cannon *High Power*
Introduction: Steel Pipe Air Cannon *High Power*
         I made these high powered SteamPunk cannons using Steel pipe and fittings that were laying around (Free) although if you do not have accese to a steel yard or steel fittings, this project is probaly to expensive for you :(. Just layed out the peises until I liked the look of it [longer barel, large tank/air capacity, and trigger valve position are things to pay attension to], and put the pieses togeter using teflon tape, a vice and a pipe wrench. The main reason to using steel piping it the finished cannon is a lot safer than PVC (at high pressures) and I personaly like the over all look and feel better (a little weight good)
      Air Cannon- My record distence was 249 feet (76 meters) with 125 psi at about 45 degrees.
      Paint Ball Cannon- Shoots at about 100-150 fps (one round at a time)
    • Paper Contest 2018
      Paper Contest 2018
    • Trash to Treasure
      Trash to Treasure
    • Epilog Challenge 9
      Epilog Challenge 9
    I am doing this! Steel fittings laying around, teflon tape, pipe wrench, vise. Valves are needed too. I will go up to 150 psi!
    Ya if you get all high thickness fittings and a compressor That can go that high along with a bunch of rupture discs and a rupture valve, you could probably shoot right through a brick wall or something. Or blow the whole thing up!
    You could also hook up a high strength electric valve for remote fire. And mount the cannon on a RC wheel base with remote aiming and adjusting... Just a thought.
    Insane! I have been using modified bolts with their heads ground round, and made to fit with rapped tape, and a ribbon to help find them. And at 150 psi I had it shooting over 100 meters. I have not tried shooting it a anything yet though.
    Awesome, be careful with the high psi.
