3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Steel Spiral Bound Memo Pad
Here's an old project I did way back High School. It's a spiral bound memo pad with steel covers so the notepad doesn't fold up in your hand. You can also scale it up to a full sized 8.5 x 11in spiral bound notebook.
Step 1What you need
What you need
You just need a small spiral bound notepad (mine's 3 x 5 inch) and a piece of sheet metal. I used steel, but you can use aluminum, tin, even plastic. Keep in mind the thicker your material the less paper you'll be able to fit in the notepad (I used 26 Ga steel)
For tools you'll need (sorry but I forgot to take a picture)
something to cut the metal (I used a grinder with a metal cut off wheel)
A drill with bits equal to the size of the holes in you donor pad
A file
some tape
a marker
and some small black binder clips
5 comments
Sep 12, 2010. 3:17 PMGreywyn says:
Another option to add might be replacing the wire spiral with a thicker gauge wire to hold up better over time.
Sep 7, 2009. 2:01 AMstephenniall says:
Oo i prefer this Cos its stronger
Jul 7, 2009. 6:04 PMRadioactive_Legos says:
I like it! i suppose the metal can also be used as a whiteboard of sorts... cool!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
27
Author:uglymike
