Stellar-X Pallet Table
Introduction: Stellar-X Pallet Table
Check out this table. I'll apologize in advance for the stock photos and the ms paint drawings. I didn't take the time to capture the build step by step like I should have. Also, I'm quite the amateur when it comes to wood working. I have a hard time putting my actions into words. I just do it--like Nike....
Step 1: Get Some Pallets
I used two pallets--buy them, loot them, find them...haha
Step 2: Rip Pallets Apart...carefully
Step 3: Figure Out What You Want to Do With Your Wood...
I began by determining how tall and wide I wanted the final product to be. I wanted to leave a slight overhang along the sides so I made the main frame a couple of inches shorter in length and width.
Step 4: Frame It Up
I chose to build a frame first so the planks would have some structure to follow. I used a "t" frame so that I could attach necessary secondary braces. The diagram speaks for it's self, really. I used the thicker supporting 2x4s (or similar) for the outer frame and the inner frame. After forming the rectangle and "t" I added a thinner strip to each side of the middle brace so I would have more surface area to attach the top planks.
Step 5: Cut the Planks on a 45
Cutting on a 45° can be tricky. I messed A LOT of good wood trying to cut the top planks for this piece. I really can't offer advice on cutting. It was a miracle that I cut enough decent pieces for this table. The diagram for this step is completely wrong-and I apologize.
Step 6: Finish It Up--attach the Planks and Legs
This step also brought out my worst. Being that pallets are all different, most of the planks weren't the same. I lined them up as best i could prior to attaching them just so i could make sure my design would work. I began by attaching the strip that runs from end to end through the center of the table. I then started in the center of the "t" frame and worked outward with my 45° planks. I left the open places for the triangles and cut and attached those next to last.
I was trying to decide what to put around the top of the table to give it a close look and to take everyone's eyes off of the imperfect planks when I noticed a piece of wood that I had ripped for an earlier piece. I had ripped a 2x4 with the grain so that the nail holes would show through. As far as I'm concerned this epiphany made the table what it is.
I then turned it on its top and attached the legs--which were also finished 2x4s. I'm not sure how to attach the legs properly--i just screwed them until they weren't wobbly.
 I used small finishing nails to fasten the planks and 2" screws to attach the legs.
Finally, I brushed a light coat of polyurethane to bring out the wood grains and seal the wood.
Step 7: Show It Off
5 People Made This Project!
  • Pocket-Sized Contest
  • Pro Tips Challenge
    Pro Tips Challenge
  • Paper Contest 2018
    Paper Contest 2018
Very nice. Great work!
Inspired by your table I made this bench seat with lid for storage inside . Its 90% pallet wood 10% decking timber. Still under $20 including screws.
Nice Andrew. Would make a great chili bin
Looks like it would be a great beer and chips seat
I used this as a basis for a desk. Changed the pattern and used pourable resin for the finish on the top.
I love this table but Im curious, how big did you make it?
Just to say a big thanks as your 'ible was a great inspiration for my own table. I bigged you up in my description.
Thanks again!
Thanks for the mention! Your table turned out wicked awesome!
I think I'm going to give this a try, but I kind of want to take my father-in-law's example and offset the star pattern. Like center it in a corner to make it asymmetrical. Better start collecting materials.
Great use of natural colours! The top would make a fantastic looking door. Well done
