3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Stencil for spray painting - quick and fun
I'll show a fast and fun way to take scraps of cardboard / duct tape / random items / etc. to make a quick stencil. With a little creativity, being light on the first spray or so, and doing it in a wind-free spot, you can make sharp stencils for nothing. Easy to leap from this idea to multi-layered stencils with different colors.
I've spray paint stenciled clothes for a while, and have a few shirts that I spray painted about 7 years ago that still hold strong. After a good hanging out to get the fumes out and a run through a washer, it's all ready to wear.
I'm planning on doing some more thorough experiments and will share notes as I go.
Step 1Make a stencil...
Make a stencil...
So if you want to spray paint a stencil a first thought might be that whatever you use for the stencil has to be waterproof/heavyduty/thick/whathaveyou. It doesn't have to be. I've used light printer paper and cut it out with an exacto to make feathers for a griffin design and that made many sprays.
The trick is to go very light with the first spray you do. If you spray a thin even coat on your paper, and let it dry, then repeat, ie, build up slowly, you get a waterproof coating on your stencil paper. If you spray too hard you can soak or sog it down and it either gunks up or rips and falls apart.
I made some stencils on a whim after pulling a cardboard donut out of a 2gal glass bottle I bought and thinking it would be a nice frame for a stencil.
The other bits are just duct tape and printer paper cut after being folder over 2wice and cut out with scissors (I reinforced their bottom with ducttape).
7 comments
Sep 6, 2009. 7:18 PMMaggithaMay says:
I've found that rubber cement works really well for holding down the stencil. It makes a really crisp outline, it's really easy to pull the stencil off when you're done, and the glue rubs right off the fabric.
Dec 18, 2008. 1:31 PMcowscankill says:
Hmm... seems like it would be hard to do for a complex design, but then again you would need to cut out the complex design from any stencil lol.
Nov 23, 2008. 6:29 PMuguy says:
2gal o booch?
Sep 16, 2008. 9:38 PMFreshPineSent says:
What kind of spray paint did you use?
Jul 18, 2008. 2:32 AMDuctTapeRules! says:
I've used this technique before, turned out pretty good. Nice 'ible!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
23
Author:lazlow69
