Stencils with Islands - Pt. 2 by fungus amungus
Featured
So you want to spread your message with spraypaint, but you don't want your designs to be held back by worrying about pieces of a stencil connecting? Just use some cardboard, wire, and duct tape and you're ready to do the "impossible."
Big thanks to Tim Anderson for taking the action shots.
Step 1: Cut Your Stencil
Here I took Aphex Twin's symbol off the ol' Interweb and converted it into a vector drawing with Illustrator. I then cut the design out of cardboard with a laser cutter. You probably don't have this costly bit of gear at your place and neither do I. I just make do with what others are kind enough to let me play with.
The low-tech version would be to print out the design in reverse, tape it to cardboard, and go nuts with a box cutter or Xacto blade. But that's another story for another Instructable and you're smart and clever enough to figure it all out, right?
After you've made your cuts, put all the pieces back together. This is how you're sure the placement is right.
Step 2: Get Some Pieces of Wire
Cut it from a spool, straighten out some paperclips, or snip out sections from a coat hanger that's lost its crappy little cardboard tube. Four or five inch lengths are great. Three inches is good, too. Just look at the next step and your needs will become clear.
Move along.
Step 3: Make some wire bridges
You're now going to "bridge" the gaps to the islands. Place at least three wires from the outside of the stencil to the island in the middle. Two are good for a quick job, but three will give you a solid connection. Four are even better. Five starts to get silly looking. Six are goofy. Seven starts to get kinda cool again. Eight is glorious. Nine sucks. What the hell was I talking about?
Step 4: Tape 'em Down
Secure the bridges! Ready the ramparts!
OK, this is duct tape. Duct tape on cardboard. Duct tape that is holding wire onto the cardboard. I'm sure you're not even reading this. Absolutely positive. Crap, I need some more wine.
Step 5: Holy crap! It's holding!
OK, no big shocker, eh? Kind of anticlimactic, huh? But holy crap, it freakin' works!
Step 6: Stick It, Spray It
Place the stencil on a nice and legal target, such as a piece of masonite with a big blue tarp behind it. The tarp was stained with some previous efforts at something... else. I really have no clue what that is. Make it up.
Oh yeah, then spray it with some spraypaint. Be smart and get a can that isn't about 40 years old that you found in the back of a closet. But if you're gonna make something to put up online, then grab whatever. These small pictures hide the gruesome details.
Step 7: Enjoy Your Stencil
Cardboard is thick and the gap is big enough (3-4mm) between the top where the wires are to the target surface that the bridges will become completely invisible.
This is one method, there are others. I made this method up myself, but I'm sure I wasn't the first by a long, long shot.
This is one design of infinite possibility. Copy it from a source like I did here as an example or make something new. New is better.
Push yourself. Post your own efforts in the comments or simply spread it to others around you.
1-40 of 42Next »
Kirbsome! says: Sep 25, 2011. 3:45 PM
Simple and clever. Love it.
ilpug says: Aug 9, 2011. 9:33 PM
this is known as wire bridging. very useful, but i reccomend using fishing line in place of wire. its harder to attach but creates less lines. im glad someone showed how to do this, few people know it. i figured it out myself before i knew it had already been done.
typo3150 says: Jun 27, 2010. 5:31 PM
Photo v. helpful! Did you know that silkscreening is thought to have developed this way, from women tying silk threads to stabilize paper cutouts in Japan or China I think …
arudiver says: Jun 13, 2010. 5:16 PM
what settings do you use in the laser to cut the card board and not burn it completely? I have a 75 Watt machine. thanks
l96470fps says: May 12, 2010. 12:48 PM
if u want an everlasting stencil, use plastic, and chicken wire, i just thought of it, great idea, great ible
xilefakamot says: Jun 17, 2009. 9:31 AM
I've always wondered why people never do this - it's so simple! If you're using this cardboard, you could always bend the wire up then down to make an arch over the gap
KoolAidDisaster says: Jan 6, 2009. 5:03 AM
i think you need some work on your spray technique lol just playin man i need some wine too lol good job
OutOfStep says: Nov 14, 2008. 8:37 AM
I think you murdered someone on that tarp. Good idea no less. Where do you attatin this laser cutter?
california145 says: Aug 28, 2008. 8:58 PM
great idea, im such a dumbass, ive been stenciling for years and hevent figured that out
FunkNattidelic says: Aug 20, 2008. 6:57 PM
My friends and i just recently (i mean just five minutes ago) made a large Boo stencil. this wouldve helped alot, there are gaps left unpainted in ours... =P
RyanV says: Jun 15, 2008. 12:51 AM
Thank you so much for your tutorial! IT certainly made a first time stencilers project easier!
Sgt.Waffles says: Dec 30, 2007. 11:19 PM
Badass. I approve.
Whaleman says: Sep 12, 2007. 8:30 PM
Sweet! I have always used tape, but then the pieces could shift, this is way better! This is the stencil I am making.
GorillazMiko says: Aug 21, 2007. 8:28 PM
Dude, you guys don't have to change anything, this is a quick, easy, and great instructable.
pinski1 says: Aug 30, 2006. 7:36 AM
Surely if you used thinner wire you could use thinner pieces of cardboard? You'd have to watch them for breakages, but if the wire wasn't too thin it's be alright.
fungus amungus (author) says: Aug 30, 2006. 9:18 PM
This techique is easily modified. I cut this out of thick cardboard because the laser cutter did all the annoying work for me. This makes for a sturdy stencil that can easily be tossed into a backpack, although you'll still need something strong and flat so it doesn't get bent, like that piece of masonite.
If you want, you can cut thinner cardboard or even card stock. Cereal boxes work pretty well and who doesn't want to dig through the extra massive bag of Cheerios?
I forgot to mention it in the instructable, but another use for this is to help secure long peninsulas. Spray enough times and the cardboard or card can get a bit soggy and droop a bit. Wires provide the extra support until you can afford to get a stencil custom cut from masonite. These guys can cut a piece for you. Costs money, but if it's out of the hardboard it should last forever. Cutting the same design over and over on flimsy stock gets old.
Ribs says: Jul 28, 2007. 2:21 AM
can a laser cutter cut masonite? cause if it can you could just make your own!! it may seem like a dumb question but i dont know this stuff
fungus amungus (author) says: Jul 31, 2007. 12:06 AM
It can. That link I had before is a service that does just that. I've cut several masonite stencils and they rock. I used cardboard as an example because laser cutters aren't easy to come by.
AlphA303 says: Jul 30, 2007. 2:10 PM
Sweet idea.
Grendel says: Aug 30, 2006. 6:10 AM
You can also use screen material (like you use on a door, porch, or window) and glue to make a stencil for both spraypainting and screen printing (and spay screen printing!) Now if I knew of a spray paint that would make it thru the washer without ruining things...
CaffeineHouse says: Jul 16, 2007. 12:41 PM
actually the mesh used in screen printing is a lot finer than the stuff you'd use on a screen door, and if you used actual silkscreen or the like, the spraypaint would gum it up immediately.
fungus amungus (author) says: Aug 30, 2006. 9:10 PM
You could do that, but spraypaint will quickly fill up some of the squares if you aren't diligent about cleaning it off. Also, I never have any spare bit of mesh lying around, but I have a veritable bounty of paperclips and clothes hangers just waiting to be put to work.
neuralstatic says: Jun 18, 2007. 1:41 PM
bingo.
master-of-chaos says: Mar 28, 2007. 5:22 PM
nice
hughdowner says: Jan 23, 2007. 2:51 PM
Why didn't i think of that?!
gary delatte says: Dec 7, 2006. 3:36 AM
hey. my first post as a new member.if you use plastic cardboard (available after any locol election,ask first ,the people with them in thier yards will let you have them for free)insted of paper and your stencil will last long enough for you to get tired of painting things.i love this site,you guys are increadable.but i think some of you have waaaay too much time on your hands,lol.
neural_cosmonaut says: Aug 31, 2006. 4:36 AM
excellent, but another sturdy and fairly economical way to further secure your creation is to use a hot glue gun to hold the wires in place. less likely to shift during transport, etc. just keep some duct tape handy, just in case.
fungus amungus (author) says: Sep 1, 2006. 12:23 AM
True, that's another method that works. It's just quibbling over an adhesive, but I like the tape just because I don't like waiting for the glue gun to heat up.
Kactapuss says: Oct 24, 2006. 9:46 PM
lol, i totally feel you on that one, whenever i MUST use the glue gun, i hold the tip after i pulg it in so i know the instant that it's hot enough to use.
kennytatheguy says: Sep 27, 2006. 8:36 PM
YEA! GO APHEX TWIN HE ROCKS
FrenchCrawler says: Aug 28, 2006. 10:51 PM
Cool idea, now if I only had something to spray paint...
TheCheese9921 says: Aug 29, 2006. 11:19 AM
walk downtown and spray paint garbage cans allyways street signs ext
FrenchCrawler says: Aug 29, 2006. 1:35 PM
Um.... Live in the forest.....Kind of surrounded by trees. Spray painting trees won't work neither cause for one thing it makes toxic firewood and two the bark is too rough.
Grendel says: Aug 30, 2006. 6:05 AM
There is a spraypaint you can use actually on trees. Its designed to not harm the tree, many city / county governments use it to spraypaint trees pink at christmas time to keep people from cutting down public trees. I don't know the name of the stuff off the top of my head butt I've seen it while driving down the interstate, and on CNN a few times.
kellusion says: Sep 21, 2006. 2:37 PM
Its probably the same kind they use to mark hiking trails too, I'd imagine.
brob says: Aug 30, 2006. 11:59 AM
interesting. Didn't know that,
stonehenge360 says: Sep 4, 2006. 10:02 AM
good job. another great instructable is http://www.instructables.com/id/E4LPDFFE1UEP286IW9/ which does the same basic thing on a laptop.
nak says: Sep 1, 2006. 3:19 AM
Cool! Ive been getting into stencils the last couple months. (props for aphex twin)
antirem says: Aug 29, 2006. 3:39 PM
I posted that the aphex twin pic cause i made it in to a shirt before, for a second i was like, oh man someone else is making aphex twin stencils too ive seen wire used before but the reasoning for it didnt connect at the time. Great job im going to try this one soon!
fungus amungus (author) says: Aug 29, 2006. 1:41 AM
The whole thing came out of this conversation, so thanks to Anitrem for that. Since the challenge was an Aphex Twin icon I had to do it. Haven't listened to him in a while, but man did I used to play that stuff loud back in the day.
1-40 of 42Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
