3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Stencils with Islands
When making a stencil the "impossible" trick is to create an island, a blocked out section of the stencil that isn't connected to the side. I wanted to apply an image only once so I made this technique to have easy and clean islands. This works for applying fabric paint. For spraypainting there are other methods that can be used, even reusable ones.
Step 1Put Together a Design
Digging back into the old-school video games is always good for some easy stencils. It's all right angles with the pixels blown up. Here's a version of one of the alien ships from Space Invaders. The two eyes are some easy islands to deal with, although I've used this technique for smaller and curvier pieces as well. Be sure to use the Find Edges filter so you don't use up as much toner.
39 comments
Aug 9, 2006. 1:11 AMautonomouschimp says:
You can also make "islands" by making your bridges super skinny (2mm or less) and using a roller to heavily apply the fabric paint; it will bleed under skinny bridges. Also works for spray painting. This method is best for producing multiple prints from the same stencil, although the bridges will eventually weaken under many layers of paint.
Jan 25, 2010. 10:01 AMflytape8490 says:
won't the paperclip show up in the spray though?
Jun 4, 2008. 12:15 AMbudman0312 says:
If you make a t-shirt with spraypaint, do you use normal spraypaint or is it made special for fabric/textiles?
Jul 16, 2007. 5:27 PMPetervG says:
This is the stencil I will be using.
Jan 1, 2010. 5:35 PMmatthew5384 says:
 combine logo from half-life 2
Aug 11, 2009. 11:06 AMRobert L says:
Thats Aweosome I made one and love it. Where did you get it
May 22, 2008. 3:17 PMscamp says:
but theres no ilands on that sentilce peter
Dec 22, 2007. 7:26 AMBuffaloNickel says:
ahooospraypaint... scuze me
Jan 12, 2009. 2:37 PMmg0930mg says:
Spraypaint washes off easier then fabric paint.
Apr 15, 2008. 8:28 PMGorillazMiko says:
It doesn't wash off?
Jul 16, 2007. 1:11 PMPetervG says:
The person at my art store said that spray adhesive would ruin it, and that Fresco would work well.
Jul 16, 2007. 5:00 PMPetervG says:
The fabric I think. I wasn't to sure, but I'm using some sticky paper.
Jul 22, 2006. 5:46 PMPetervG says:
Great! You can also buy some cheap print out and iron on T-Shirt things. They are called ink transfer sheets or somthing like that.
Dec 20, 2006. 12:52 PMjavguerre says:
yes, but what if you cut the excess film away before ironing on the design?
Jul 14, 2007. 7:05 PMPetervG says:
Yea, I made that T-Shirt like a few months ago. It sucked and started cracking. DONT USE IRON ONS. I think I'll just go buy some paint for $10 and paint on the 2nd shirt I bought.
Jul 8, 2007. 9:06 PMHIGHVOLTAGE-Z says:
i dont know if somebody said this but you can just get sticker paper from walmart. cut out and stick on islands.
Nov 27, 2006. 6:03 PMBad Donut says:
Instead of a paint brush, use a Squeegee. That way you can get alot more paint on without wasting too much of it.
Dec 2, 2006. 1:16 AMerfonz says:
If you use a squeegee on a stencil, a lot of the time that will make it bleed through the shirt and make it look bad.
Jul 22, 2006. 6:56 PMNuSuKi says:
Hi, I have a question about step4. What kind of spray did you use for sticking the paper? It's a glue-spray or something? Thanks! PS: Excuse me for my english ;)
Jul 23, 2006. 11:10 PMando says:
there's an easier way to do that: use reynold's freezer paper. you can print the stencil on the paper-y side and then you iron it on, once you've cut the stencil outline out. it works great! it would probably be harder to do islands with it, though
Oct 26, 2006. 10:35 AMkuhtams says:
I second this idea. I use freezer paper for all my stencils and it works wonderfully. You can get some serious detail in there and you don't have to worry about the residue that spray adhesives can leave behind on the item that you stencil. To avoid having the island misaligned, you can leave teeny bridges that you peel off after ironing the design in place but before you roll the paint.
Oct 1, 2006. 1:05 PMBad Donut says:
Thats awesome
Jul 22, 2006. 6:21 PMantirem says:
wouldnt two stencils be easier?
Aug 17, 2006. 5:07 PMsinistlor says:
I agree, the essence of this lesson was the continuous strokes. Just for kicks, if you did make a solid color one, I think splitting the stencil into these two passes would work well:
Aug 9, 2006. 6:39 PMGiveMeMyCawwot says:
this would work with spray enamel too...
Jul 22, 2006. 6:51 PMradiorental says:
a different take on roughly the same process, larger scale
http://www.instructables.com/id/EC1UHP4JSEEP286QXC/
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
1414
Author:fungus amungus(my site)
I like to make things both useful and odd. The odd projects are usually more fun. I'm also the Content Manager here at Instructables. Follow @edabot for more
