loading
Step 3: Installing Kon-Boot on USB.
When you have downloaded kon-boot-all.zip and UNetbootin open up kon-boot-all.zip.
In kon-boot-all.zip open the folder "kon-boot-all *" then double-click the CD Kon-Boot zip file, example: CD-konboot-v1.1-2in1.zip. When it asks for a password type "kon-boot" to get access to the folder with the .iso file.
Open the folder appearing and extract the CD Kon-Boot iso file, example: CD-konboot-v1.1-2in1.iso to your desktop.
Start UNetbootin as we downloaded before and choose "Disk image". Then click the button with the three dots and locate your CD Kon-Boot iso file. When you are finished doing that choose the USB drive you want it to be installed on. Click ok and see it do magic.
Your done you sucsessfully installed Kon-Boot on your USB stick.
<p>Mirror for Kon-Boot v2.5 (Supports Windows 10):</p><p>http://www45.zippyshare.com/v/dHbLIfow/file.html</p>
<p>Can't use this program to reset Windows 10 password. If you had the same issue as me, then I suggest using UUkeys Windows Password Mate instead. It only took me 5 minutes to reset the login password:</p><p><a href="http://www.uukeys.com/kon-boot-not-working-on-windows-10.html" rel="nofollow">http://www.uukeys.com/kon-boot-not-working-on-windows-10.html</a></p>
<p>I used this but it is not Crack or hack my windows password i think i have take some misstake at the time of uses but thanks for sharing </p><p>www.softwaressvalley.blogspot.com</p>
<p>It is a great tutorial, I have been using Kon-boot on CD for about 4 years and maintaining disc scratch free is a pain. I did follow your tutorial but was not successful when trying to bypass the password. The bootloader has gotten stuck on the grey loading screen with the count down. It tends to cycle it self over and over after it counts down to 1, never loading onto kon-boot or windows in that fact. I have read on several forum a quick fix for the problem. When loading the kon-boot image do not choose &quot;ISO&quot; instead choose &quot;Floppy&quot; which should work pass the cycle boot problem and into kon-boot and windows. </p>
<p>Thanks for the info :)</p>
About This Instructable
358,073views
12favorites
License:
Bio: I make things, just like everyone else around here.
More by Bjarke:Mysterious treasure riddle thingy Reliced paper Belt Strap on Vintage guitar
Add instructable to:
