Step-n-Start - A Motor Pull-Starting Assist for Those that Need a Little Help
 by yeltrow
Featured
Step 12: Bolt the Hinge onto the Base Board
The "Base Board" is the 48" 2x4 that doesn't have a pulley bolted to it.  It gets a hinge in this step.  We traced the hinge to make sure it didn't move while we bolted it on.  Then we drilled pilot holes for the 1/4" bolts.  A washer goes under each bolt head.  The 1/4 x 1.5" lag bolts we used to hold the hing on.  If you use a different style of hinge you may have to use flat head screws instead of hex heads like we used.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
