Remove these ads by
Signing UpStep 1Tools/Materials
Tools:
- Soldering Iron
- Solder
- Desoldering Braid
- Hemostats or SMD Tweezers
- Wire strippers
- Wire Cutters
- Hot Glue Gun
- Dremel Tool
- Safety Glasses (wouldn't want to lose an eye, would you?)
- Stepper Motor (Either purchased or preferably salvaged from old broken electronics. VCRs, Printers, and DVD players are particularly good sources for stepper motors)
- Wire (22-26 gauge is ideal, instead of buying new wire, wire can also be harvested from existing cables. Old ethernet cables are particularly good sources for large amounts of wire.)
- Blue SMD LEDs (my project uses 6, but feel free to use more)
- Through Hole Resistors (I used some 150 ohm axials I had lying around, but depending on your led, you may want to size it accordingly. For those of you unfamiliar with electronics, this LED resistor calculator should help you figure out what resistance value to use.)
A quick note on safety: This project uses certain tools that could present a risk of injury. Eyeglasses are strongly recommended, and care and common sense is needed for safe operation of the dremel tool and soldering iron. The author of this instructable assumes no responsibility for injury or accident incurred while working on this project. Please, be safe and have fun.
Here's to the First Iron Man 2 build!
