Remove these ads by
Signing UpStep 1Gather Supplies
a. light box(tent)*
b. camera (USB cable optional)
c. tripod (optional)
d. object to be photographed (CPU in this case)
e. angle tool (a.k.a. a paperclip)
f. pair of pliers
g. bits-o-knowledge
- My crude light box(tent) was made by losely following this instructable:
- I didn't spend that much time on my light box(tent) because I would be photographing a small object using a shallow depth of field.
On the other hand, I can do easily the parallel view (maybe I'm just used to it). If you look at Wikipedia article, some of the image pairs are for parallel view and others are for cross view.
If you swap the left and right images of your CPU, then they will be for parallel view, and then I'm able to see it. However, some people might need some equipment to do that.
My suggestion is that you should post both versions (parallel and crossed views) on your instructable.
(another small suggestion is to convert the inches to centimeters too)
These 3d pictures would be better viewed by arranging them for parallel view and looking with a stereoscope (AKA stereopticon), which would have (for ease of viewing) prismed lenses. Hmm, there's an instructable idea, make your own stereopticon prism.
Additionally, you don't need to use a light-box setup at all. For any still image (streets, houses, plants, whatever), just take a second picture of your subject after moving your camera to the right. Move it only a few inches to reproduce your actual experience, move it a lot to increase the 3D effect (and make the scene feel smaller). Just make sure that you're aiming your camera so that both lines of sight are parallel, rather than aimed in at your subject.
You should be able to use the "straight eye" technique to view this image as well. In other words try to look past the image. I can almost get it but it's just a bit too wide or maybe my eyes are too old.
Either way, nice job.
