The beautiful thing about Super 77 is that it is relatively cheap ($5-$10 depending on your area) and can be found almost anywhere. It can adhere most products, such as paper, fabric, films, plastics, wood and foam.
This multipurpose spray adhesive is a great, fix all product, that generally is cheaper and better that many specialty adhesives for things like photo mounting! When properly used Super 77 normally does not distort or bleed into your material, which is one of the main reasons I choose this product over other adhesives. That being said, always test the product on a scrap piece to make sure it will work for you!
Remove these ads by
Signing UpStep 1: DISTANCE DISTANCE DISTANCE!
Another good point to make is to not build up the adhesive layer on your material. Spray adhesive works very similarly to spray paint. If you spray to much, it will not dry properly, and it will do weird things. One light pass over you material should do it, if you need, another pass will be OK! The goal is for the sprayed area to have an even, light spray layer, and to not have any sort of buildup or irregular texture.
Visit Our Store »
Go Pro Today »
I genuinely want to know how that works out for you. I am always on the lookout for other useful product. I assume this object may get some wear and tear, lets see how it holds up!
For super strong bonds, you can spray both components, and allow them to get tacky, then stick the both together.... BAM!
