Stirling Engine
17,236
64
Posted in TechnologyScience
Introduction: Stirling Engine
Before I start here is the Wiki page to explain what a Stirling Engine is:
http://en.wikipedia.org/wiki/Stirling_engine
Step 1: Auxiliary Cylinder
I made my main cylinder by soldering a piece of metal to the bottom of a pipe.
The metal came from a old metal lid. Before use just scrape off all the plastic so as to not create toxic fumes when heated.
Step 2: The Auxiliary Piston
Finding a sealed piston was too hard so I decided to stuff a tube with aluminum foil.
Note the piece of wire that has been embedded into the foil.
Step 3: Main Cylinder
This is the piston that provides the power.
It was been made from a copper tube with another piece of copper soldered on to the bottom.
My soldering iron did not have the power to solder on to the large piece of copper so the joint is a bit dodgy...
Step 4: Main Piston
I was lucky enough to find a piece of plastic that was perfect for the piston
Step 5: Crank Shaft
I had a gear set with gears and a shaft so I just drilled holes and attached bars across two gears and cut out the middle.
Step 6: The Heat Sink
There is a few too many holes but it still works.
I hammered the small tube in after drilling a small hole.
Step 7: Holding the Shaft
I did not have a spare hard drive head like all the other Stirling engines but I did have spare metal with drilled holes... And a lot of lubricant.
Step 8: Fly Wheel
The only thing that was round enough is CDs =)
Step 9: Holder
I found a old school compass which make the perfect holder. I made a retort stand from wood and a metal rod.
Step 10: Assembly
Assembly took some time to get all the fiddly bits right but when it came together it was all worth while.
Step 11: Results
    • Spotless Contest
      Spotless Contest
    • Microcontroller Contest
    • Space Challenge
      Space Challenge
    2 Comments
    Awesome, i have been studying Stirling Engines for a week, cause i was thinking of trying to make one, and i just couldn't figure out how the Temperature exchange was working, I read the Wiki, and alot of other material, but when i examined your tutorial as crude as it may look, it just ignited the light bulb in my brain. I finally understand thanks to your instructable. Knowledge is only useful if you know how to use it, and thanks to you i now understand why it works, and how i can use it. Thank You! :)
