Although I had never actually kayaked before, one day I decided to make a stitch and glue kayak. For a non-kayaker I'm not sure why, but it had to do with a rowing class I had taken once, and I wanted to get out on the water on my own boat. Also, building a rowing shell seemed difficult, better to start with a kayak.
For those of you who don't know, stitch and glue is a well established method of building all kinds of boats. It involves cutting plywood into the right shapes, stitching the shapes together with wire, and then permanently gluing the whole thing up. A quick web search will yield loads of info about it.
There are some really nice kayak building kits out there, and you will definitely get better results than I did with a kit, but I'm pretty happy with how my kayak turned out. Also the kits can be a little pricey and I am going cheap. These online sites also sell plans which are much cheaper than the kits: Chesapeake Light Craft, Pygmy Boats, One Ocean Kayaks, and Shearwater Boats.
There's a few free kayak plans on the internet. There's one called the Guillemot and there may be some here, here, and here, but I chose the Sqeedunk C-16 because it looks a little easier to assemble. Now these aren't exactly plans, they're really just points you mark out on the plywood, then play a interesting game of connect the dots.
Another option for the true DIY'er is to design your own kayak using FreeShip, DelftShip, or your favorite 3D CAD software. Just be sure it is capable of unfolding curved surfaces, so you can take the curved panels you design and flatten them out for the plywood. A word of warning: CAD software typically has a steep learning curve. You may end up spending a lot of time working at the computer.
For materials, you will need some thin plywood. Everyone in the kayak biz will tell you to use okoume marine grade plywood, and they are right. However, since I'm going cheap and I just want a recreational kayak I can play around in rather than a serious sea kayak, I bought two nice looking lauan 4'x8' pieces at Home Depot. They are sometimes called door skin and are about 1/8 in. thick. Here's a tip, use a flashlight to shine light thru the plywood and look for gaps or voids in the middle. Voids are bad.
To start off with I bought, 30 ft of 6 oz. fiberglass cloth, a gallon of epoxy resin and half gallon of hardener from this online site. I also bought several feet of solid copper wire at the hardware store. It was red and white 20 gauge wire for antennas I think. Make sure it's solid, stranded wire will not work.
This was a really long project, it took me around 8 months, but there were weeks that I didn't get any work done. If working on it full time, it could be done in less than a month.
For tools, I used a coping saw and key hole saw to cut the plywood although some people recommend the japanese style pull saws. A power circular sander is a must. I used many a 60 grit sanding disc. You will also need a seemingly endless supply of sand paper, disposable brushes, and latex gloves. Other tools: rasp, carpenters square, drill, utility knife, safety glasses, pliers, etc.
Remove these ads by
Signing UpStep 1Scarf the sheets
The boat I chose to build is a 16 footer, but that's way more boat than I need and I don't want to store a 16 foot boat. Also it would require attaching three 4x8 ft. pieces of plywood together. I decided to shrink the boat down to a more manageable size, but more on that later. Shrinking allowed me to attach just two plywood sheets together.
To create the edge, I took a 2x4 board, and placed a scrap piece of plywood on top of it. Then I placed one sheet pretty side up on to the stack, and the other sheet pretty side down. This way the pretty side doesn't get damaged during the scraping and sanding. The boards are offset by 2 inches then I placed blue tape 2 inches from the edge of the top sheet to let me know that I should not cut into that part. I used a C clamp to keep the stack from moving. Then rasp and sand it down to a nice smooth slope.
I kept as much saw dust as possible to thicken the epoxy later in the build. The thickened epoxy is useful for squishing into the corners for a stronger joint.
Glue it together. I used water resistant wood glue because I was waiting for the epoxy to arrive, but I regret it. Using epoxy will blend in better with the later epoxy coatings. I swept the floor and laid down some plastic wrap to avoid gluing the sheets to the ground. I then placed the bottom sheet down and applied glue. Next came the top sheet followed by another layer of plastic wrap. Finally I topped it all off with scrap plywood and weights to make a tight bond. Let it dry for a day and you should have one long 4x16ish sheet of plywood.
You will still need to coat everything in the epoxy to properly seal it.
First of all, i have already designed the ship body which i want with freeship.But i didn't figure out how to develop each curved surface.Does it need the assistance of CAD?
Secondly, how could you cut the plywood into shapes which are needed? By craft or by water-jet?
Thirdly, the maximum size of my plywood is 1220X2440mm. It is necessary to be adhered with yours.I would like to know how to assure the rubber-determination of adhesion?
Forthly, i am thinking about to replace the plywood by PVC board and make another 4 Bulkhead inside the cabin intended to reinforce the strength of shipping.In this case, the method with fiberglass could be omitted. What's your opinion?
Happy Spring Festival (Chinese New Year)and may you be prosperous!
I didn't use Freeship, but from what I understand a surface is developable when it bends in only one direction. The tool should be able to show that. Check Developable in the layer properties. Also, check out section "13.4 Develop plates" of the Freeship Manual 2.6
For cutting the plywood I used a hand coping saw. A more high tech solution would probably work, but subjecting the unprotected plywood to water might cause some damage.
I suggest connecting 2 1220X2440mm sheets of plywood using the scarf method. With epoxy the adhesion is very strong.
A PVC board for a bulkhead might work, but be sure the epoxy can stick to it. Since it is nonproous it might not work. I didn't fiberglass my bulkhead, it's just painted with epoxy and varnish.
Good Luck with your build!
I will try to make a boat with other materials, but I just graduated from university, need to work, do not have enough time to complete, so some time before this site posted.
http://www.guillemot-kayaks.com/guillemot/information/kayak_building/stitch_and_glue_construction/free_stitch_and_glue_kayak_plans
be proud that you made it by yourself.
thanks for the instructable
and nice ible too!
approximately how much does she weigh?
http://web.archive.org/web/20070314064231/www.squeedunk.com/c-16.htm
