3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Stolmen and Ekby compression bookshelf system
[Better project-complete photos added.]
An absurd set of requirements leads to a hacked compression shelving system for easy maneuverability and expansion.
Goals
Recently I 'earned' some upgraded bookshelves.  Having casually shopped shelving for a while, I knew I had some rather absurd requirements:
*  easy to break down and transport
*  useful as a free-standing divider or against a wall
*  adjustable to varying ceiling heights
Inspiration
A few years ago I chanced across Julie Scheu's "pogo" free-standing bookshelves.  I wanted them immediately.  Since they were a commissioned piece for a gallery in New York, I opted to build my own version.  In metal.  From ikea parts.
While researching compression shelving (the official vocab, it seems), I found sites devoted to pre-built systems.  Most were for commercial use—boring and expensive at the same time.  Thankfully, a site comparing compression shelving referenced ikeahacker and Lucien's stolmen/jarpen shelves.  Hack-tastic!
I integrated the two ideas using Ikea's Ekby shelves, Stolmen poles & brackets and some alternate parts.  Identifying the alternate parts was a chore, due to Ikea's habit of not providing schematics.  However I'm happy to share the results of my trial-and-error process that will hopefully make things smoother for any other ikeahackers using Stolmen parts.
Let's begin the short 'n sweet tour.
Step 1Stolmen poles
Stolmen poles
Be sure to test the telescoping in-store if you can—I had to return two of the four poles I bought for broken telescoping mechanisms within the poles.
Stolmen poles: $30 each
Shelf finish selection
Ekby's Mossby edition isn't as flexible as the Jarpen edition that Lucien used, which can be cut and stained as needed.  But I preferred the metal look.  To achieve two poles and the suspended-shelf effect, I needed to pinion an individual shelf on its centerline.   To do so, I drilled through the metal covering and pressed wood core.
The metal is very thin and punches through quickly if you're not careful, so take your time.  It also gets hot due to friction, so mind your fingers.  I drilled from the bottom of the shelves toward the metal top, to make sure I wasn't introducing alignment problems.
Ekby Mossby shelves, 31 1/8" x 7 1/2": $30 each
Stolmen brackets
They package a lot of spare crap with these.  Between 4 poles and 16 brackets, I have a whole shoebox of duplicate stuff I never intend to use.
Stolmen brackets:  $15 for a six-pack
I used 32 brackets, half double-tongued for future expansion and half single-tongued for the exposed side.
30 comments
Apr 5, 2012. 5:58 AMoaskul says:
I made sure to make the bottom feet flush, and my shelves have been standing and stacked full of books for over 6 months without problems. Thanks!
Jun 16, 2010. 12:05 AMClayfig says:
looks like the poles that your whole project is based on are no longer available i think, you link is dead for sure
Mar 30, 2012. 1:30 PMColumbusGEEK says:
http://www.ikea.com/us/en/catalog/products/20179940/
Different color, but looks like the same pole.
Jul 20, 2010. 6:55 AMbeyonddc says:
Yea, looks like the poles from Ikea is no longer available. Is there any alternative? I am having difficulty to find alternative tension pole from the Internet.
Mar 18, 2010. 1:56 PMBerkana says:
 You see that gap between the floor and the bottom of the pole? That's what I'm talking about. Close that gap; the pole should be resting directly on the feet. If you don't, that plastic end piece where the bolt is threaded through will fatigue and fail within a year. It can't take the sustained weight of a load of books.
Mar 22, 2010. 5:27 PMBerkana says:
 My suggestion is to not rely on the locking nut; let the foot rest entirely on the end cap, and extend the tube upwards to lock it in place, rather than extending that bolt downwards to push the rest of the tube up.
Mar 23, 2010. 9:17 AMscorby says:
I would like to second (and 3rd and 4th) what Berkana said, for exactly the same reason.  I learned the hard way, LFMF.
Mar 19, 2010. 7:53 PMbordenkecher says:
 are the polls then tension mounted b/w the floor and the ceiling? so that you're not actually drilling a whole in the floor or ceiling to install the shelving system?
Apr 18, 2010. 6:51 AML-A says:
 Exactly, the pressure simply keeps the feet in place. That's the big advantage of compression poles :)
Mar 22, 2010. 6:46 PMicerabbit says:
Love the project.
However, without additional fastening - like a hidden attachment arm / bracket somewhere higher up, securing it to the wall behind it  - I don't think this is a safe setup.
I have sincere doubts this will not tip over at some point, unless it were secured with flanges / feet with screw holes at the floor & ceiling. You can't set much tension so as to not damage the ceiling, ...
Just my cautious 2c.
Mar 18, 2010. 12:31 PM56dustbunny says:
I really wanna do this but it comes out to be pretty pricey, awesome hack. I'm gonna keep this bookmarked for future project. Great choice of beer to work with :)
Mar 22, 2010. 4:29 PM56dustbunny says:
OMG I was so pissed at the comment on the Unpluggd/Apartment Therapy post that I had to comment back in your defense !
Mar 20, 2010. 6:02 PMfreakshow17 says:
In regards to oyur DOGFISH HEAD BARLEY STOUT - I believe that is an official Irish Unit of Measure
Mar 19, 2010. 10:03 AMurwatuis says:
seems to me the inexpensive alternative is to use 1.5" PVC pipe, 12" wide pine shelving, and hose clamps. It may not have spring loaded tension poles but I think it would be possible to have adjustable poles using threaded pipe fittings and threaded rod. I would try 5/16ths or 3/4 threaded rod for adjusting the feet with strong support. A can of silver spray paint would give a nice metal look if thats what you like. I bet you could do the same project for $50 or less per shelf unit.
Mar 18, 2010. 8:18 PMchello2k9 says:
I would like to see alternatives material used, the price of this shelf is a little much, but the shelf itself looks nice.
Mar 18, 2010. 1:54 PMBerkana says:
 This is the part of my Solmen set that failed when my shelves collapsed. Make sure this is entirely resting on the feet; the bolt and plastic cap should not be load bearing, because they will eventually fail and collapse into the tube.
Mar 18, 2010. 1:47 PMBerkana says:
 I've done this before using the Stolmen poles, however, I have an important warning for those who try this.
My shelf collapsed after several months; the plastic caps at the bottom failed, and fell into the poles. There is a very important trick you need to do to prevent this from happening: Make sure the bottom screw and foot are all the way into the pole, so the weight being transferred through the pole rests directly on the foot without having to go through the bolt. If you don't, the plastic will fatigue, and eventually fail. When it does, the poll will fall, the top will no longer be supported on top, and your Stolmen set will fall, scattering your books everywhere.
Mar 18, 2010. 1:03 PMJayefuu says:
Brilliant first ible! I love how well written it is and that you gave credit where credit's due in all the right places. Awesome looking shelves. :D
Mar 18, 2010. 11:31 AMchella448 says:
I much prefer your shelves to these but i'm on a tight budget so..
http://www.frontgate.com/jump.jsp?itemID=25478&itemType=PRODUCT&path=1,2,137,138,&iProductID=25478&k=XX23159
Mar 18, 2010. 10:38 AMkirnex says:
 Love this project! Thanks for posting this.
And, just my opinion, but I like the looks of yours better than the shelves that inspired you.
Mar 11, 2010. 11:32 PMblakeredfield says:
Its beautiful. Very well done, piece of art. I'm wondering if whoever your design inspires next can bring down the price tag though. Well done. 5/5
Mar 12, 2010. 11:57 AMoakback says:
I bought a corner shelf unit for a bathroom that does just this, a spring-loaded telescoping pole that presses between ceiling and floor.  It was cheap (not sure how much though, it was several years ago), and I'm sure two of these could be modified into bookshelves.
Mar 12, 2010. 9:41 AMSam the Wizer says:
 Good beer choice!  Nice shelves too.  You've given me an idea of how to mount my electronic drumset.
Mar 11, 2010. 6:58 PMZansion says:
 Awesome! 5/5!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
7
Author:tiffehr(tiffehr.com)
