3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Stolmen and Ekby compression bookshelf system
Step 2Threaded tube ends
Threaded tube ends
I jettisoned the stock Stolmen feet because they look cheap.  I kept the built-in threaded tube ends however.  So I only needed new tube ends for half the project.  Due to Ikea's lack of schematics, it was a challenge to determine the exact interior diameter of the pole with the tools I had on-hand.  I decided to use DrillSpot's selection of S&W TE1-1B Tube Ends at 1-1/2" diameter and 1/2"-13 thread size.  They are actually a hair too small but using double-folded paper rings as a washer kept them in place securely.  I wrapped the paper just below the exposed top and stuffed them in.
1-1/2" tube end:  $8.16 each
1 comment
Mar 18, 2010. 1:54 PMBerkana says:
 This is the part of my Solmen set that failed when my shelves collapsed. Make sure this is entirely resting on the feet; the bolt and plastic cap should not be load bearing, because they will eventually fail and collapse into the tube.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
7
Author:tiffehr(tiffehr.com)
