Introduction: Stone Inlay Tap Handle
Picture of Stone Inlay Tap Handle
Whether you brew your own libations at home, or just consume enough of them to keep a tap on hand, the simplest way to spice up your kegerator is with a custom handle. It’s a quick, easy project on the lathe and there’s tons of room for creativity.
Step 1: Roughing Out
Picture of Roughing Out
I chose red oak for my tap handle, but you can choose any wood. I went with a simple tapered shape, but again, this is up to you! Start by roughing out the shape for your handle on the lathe. Then add some grooves for your stone inlay.
Step 2: Stone Inlay First Pass
Picture of Stone Inlay First Pass
Add stone to the grooves with thin CA glue to hold everything together. Continue all the way around the handle to fill the entire groove. Then use a carbide tool or HSS scraper to cut the stone down flush to the wood.
Step 3: Stone Inlay Second Pass
Picture of Stone Inlay Second Pass
This will look pretty rough if you just make one pass for the stone inlay. Continue using finer and finer stone to fill in the tiny gaps until the inlay is perfectly smooth.
Step 4: Finishing and Threading
Picture of Finishing and Threading
American tap handles have a standard 3/8” 16 TPI threads. To install the threaded insert I first drilled out a ½” hole. Then I used a bolt with two nuts jammed on to apply the twisting force. The insert has some paste wax, and I just kept constant pressure with the tailstock while I twisted the tap handle by hand. The finish is polymerized tung oil which I really like.
Step 5: Enjoy Your Beer in Style!
Picture of Enjoy Your Beer in Style!
Carving your own handle out of solid wood on a lathe for the sole purpose of dispensing beer covers about four of your man card obligations. If you have any questions or comments, feel free to get in contact with me here, on my YouTube channel, or on my website. Thanks for taking a look!
Just regular CA glue is strong enough for the inlay grinding? Now I'm inspired!! Thanks
haltenfelder (author)2016-02-28
I am surprised how clean this looks. Do you think it's possible to do that composite structure in a bigger scale like a half wood/half stone handrail?
Definitely!
ClenseYourPallet (author)2016-02-29
Beautiful!
cobourgdave (author)2016-02-28
Nicely done. Your video is really clear and the instructable is equally as clear. I have never thought of grinding the stone down as you did, so it was really instructive to me
About This Instructable
4,016views
109favorites
License:
Bio: Grady Hillhouse is a professional civil engineer and hobbyist everything else.
More by practicalengineering:Stone Inlay Tap HandleTuned Mass Damper DemonstrationColorful Segmented Wooden Vase
Add instructable to:
