3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Stool made from bike parts and crutches
Step 7Cut the insulation and plywood to fit the rim.
Use the rim as a template to cut a piece of rigid insulation or a thick foam pad. Then use that to mark plywood and cut the shape with a sabre saw. Cut out a 3" hole in the center of the board. This will let the hub pass through and allow the wood to lay a bit flatter. Using a sabre saw would work but a 3" hole saw worked fantastically.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
265
Author:zieak(Zieak's site)
I like making things out of items that would have otherwise been discarded. Check out my other projects! Now a PE teacher in Mongolia! I don't have much time or even the resources to make much any m...
more »
