Stop Critters from Eating Sunflowers
 by CookieDemocracy
Contest Winner
An instructable for a simple and cheap way to stop critters from eating sunflower seedlings.
Step 1: Make the Critter Shield
You will need: an empty non-colored 2-liter soda bottle, a power rotary tool (aka a "Dremel"), X-ACTO knife / box cutters.  A) Rinse out the soda bottle, and then remove the label.  B) Use the rotary tool to cut an incision in the base of the bottle from a vertical "valley" to the underside of the bottle (see pic #2).  Do not try to use scissors, a chef knife, or the X-ACTO knife / box cutters; the plastic in the base is extremely strong and you may injure yourself if you try to use a lesser tool.  C) Move to the adjoining "valley" and make the same incision.  You are trying to cut a "foot" loose from the soda bottle (see pic #3).  Due to the thickness of the plastic in the base of the bottle, you may not be able to make the incisions all the way to the center of the underside of the bottle.  In pic #4, you will see that I had to stop several mm from the center, resulting in the removal of a pentagonal (because my bottle had 5 "feet") piece of plastic from the center of the underside.  D) Repeat step C until all the "feet" are cut free.  E) Bend the feet back and splay them out like an upright octopus (see pic #5).  Your Critter Shield is complete.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
