3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Stop Motion Puppet Pt. 1
Step 6Make the joints
Make the joints
Using the 2mm. drill bit, we are going to drill the sockets for the aluminum wire. For all the pieces used to make up the arms and legs, you will need to drill a hole into each end of the dowel.
For the Chest piece, you are going to drill a hole in each end and a hole centered on two opposite faces of the basswood. The end holes will allow you to attach the upper arm segments and the holes on the faces will allow you to attach the head/neck and the lower half of the body.
For the Hip segment, drill a centered hole on the top face to attach with the upper half of the body, and a hole on each end for the thigh pieces.
Use a small nail as a center punch to mark the ends of the wooden parts, but be very careful. I had to re-cut one of the arm segments because the nail split the dowel. You just need a small indentation for the drill bit to start out on so it doesn't walk around and ruin the piece.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:smkoberg
First of all let me say that I have a problem finishing projects I begin. I just looked at my first Instructable (currently my only 'ible), which was supposed to be the first in a three part series t...
more »
