3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Stop using Ferric Chloride etchant! (A better etching solution.)
Ferric chloride is a traditional home-use circuit board etchant. It's easy enough to come by, and the Ferric by itself is no big environmental problem. However, once you've etched a board with it, you're left with a solution with a bunch of copper chloride in it. This dissolved copper is an environmental problem, and you can't just pour it down the drain (legally) -- you're supposed to take it to a hazardous waste facility. (For instance: How to Dispose of Ferric Chloride in this FAQ. )
Wouldn't it be nice if there were an etchant that you could re-use indefinitely so that you don't have to worry about disposing of the copper, and that could be made in lifetime supply for like $10.00 with ingredients bought at hardware and drugstores? (And it's prettier too.)
I got seven words for you: Copper Chloride in Aqueous Hydrochloric Acid Solution! (Exclamation point!)
But how're you going to get CCiAHAS? Conveniently enough, by starting out with a simple two-ingredient starter etchant, and doing a bunch of etching.
Step 1Ingredients: The Starter Etchant
For the starter etchant itself, you only need two ingredients: hydrochloric acid and hydrogen peroxide.
(OK, actually three. But the third one's copper. See the chemistry section for an explanation.)
Hydrochloric (muriatic acid, "pool acid", etc.) is available at a hardware store. The acid I got is 31.45% (or 10M) and should run around $5 per gallon. Which is more than you'll ever, ever need.
The peroxide is normal 3% for mouthwash or cleaning cuts, and can be bought at a drug store for $2-3 for a big bottle.
You'll also need a non-metallic container that fits your PCB and two standardized measuring cups.
As long as you're in the hardware store, pick up some acetone if you don't already have some. It's useful for removing the etch resist. (That's for another instructable.)
475 comments
1-40 of 475next »
Apr 28, 2012. 4:24 PMAaronM04 says:
I've had problems reusing the solution -- long etch times. Would it help to have an ORP (oxidation-reduction potential) meter? Would the kind used for aquariums and pools be useful for this? (they're ~$30) If not, what kind is useful?
May 21, 2012. 10:13 AMddipschmitt says:
I use a fish tank heater and a bubbler and my average etch time is 35 min.
I found I had really long etch times until I added the bubbler. Even with a temp of about 110 F it would take hours. When I built the bubbler I started getting good results consistently.
P.S.
Try putting a penny in some solution, it's pretty strange.
May 19, 2012. 10:42 AMmattgilbert says:
I don't know what an ORP is, but I had the same problem until I started using an aquarium aerator. One time I had a lot of boards in a batch, and the solution did get dark and slow, but just leaving the aerator on for a while after the boards where taken out cleared it up nicely.
May 11, 2012. 8:13 PMSam Grove says:
Except for the solder pads, the resist makes a good conformal coating for copper trace.
You can scratch through the coating on pads with your soldering iron tip and add solder or just use alcohol and a cotton swab to clear the pads.
May 11, 2012. 10:40 AMpcooper2 says:
TIP: Store the unused muriatic acid bottle outdoors in a shaded, ventilated area. They never seal quite right after opening, and the acid fumes will corrode all metal in the area. You'll be sorry if you stored it in your garage or workshop near your tool chest!
I have an old ceramic toilet tank and lid in my back yard for this purpose. The tank lid sits on the ground, I put the acid bottle on it, then put the tank upside down on top as a cover. The flush hole and bolt holes provide some ventilation and the ceramic tank protects the plastic bottle from deterioration due to sunlight.
A 5-gallon plastic paint bucket and lid will work as well, except that the plastic will gradually embrittle with exposure to sunlight and will have to be replaced from time to time.
May 9, 2012. 10:01 PMmnand89 says:
Hey I am currently doing an experiment with a copper coated silicon wafer and I am observing this problem. So I make a one pot solution of the following chemicals DI water+ isopropanol+copper (II) chloride+ a polymer solution called Methacryloxy ethyl trimethyl ammonium chloride (METAC)+ copper(I) bromide under inert conditions purged with nitrogen gas. These chemicals are used in a process called Atomic Transfer Radical Polymerization (ATRP). I dunk my wafer coated with copper, gold and chrome and leave the sample in the solution for 2-4 hours. Once I take it out of the solution, the copper layer disappears. So this has happened twice. I am definitely sure that this mixture is causing the copper to erode away. I have a hypothesis that the copper (I) and (II) salts are causing the oxidation of the elemental copper and it therefore mixes into the solution. Does anyone else have an idea about the chemistry behind this predicament of mine?
Apr 28, 2012. 10:29 PMckrause3 says:
This is the best instructable I've seen on the H2O2/HCL/Cu method. I've been using FeCl2 for years. Using a sponge to wipe across the board to break the surface tension gives me a completely etched 1/2 oz copper single side board in about 90 seconds. And now I can do it guilt free. I've been using the PulsarPro toner transfer paper for several years - take a tip from me, stop playing with magazine paper and clothes irons and go here: http://www.pcbfx.com
Feb 22, 2011. 8:25 AMElectricsrb says:
Mine board took 8h to etch. The solution is perfect I swirl the container around, but it's taken me a loooooong time to fully etch it. Am I doing something wrong?
Mar 1, 2012. 10:53 AMdarkwingz24 says:
Hi,
I have been playing around with this etchant as I have used ferric chloride in the past and it stains and is a pain to dispose of (properly). I mix up the Peroxide (3% Drug store version) and Muriatic acid (Dynamic Paint Products, no %info on bottle). The Muriatic acid definitely fumes when you open the bottle so it's strong.
I mix at 2:1 Peroxide to HCL and it etches the first boards just fine (just a couple minutes). The resulting solution is a light green and after a couple boards the colour doesn't change much and it pretty much seems to stop etching. I didn't see if it took 8 hours but after 30 min there was still copper.
I too am trying to figure out what may be going wrong. I tried adding more HCL to the bath and it didn't seem to do anything so I added some peroxide to match the HCL I added but no result (in the 30 min I had the board in). My etchant never gets that dark green/brown I see in your images. Any advice or tips?
Thanks!
Mar 27, 2012. 1:14 PMptrmail says:
be always sure that copper on your board is shiny (does not have an oxidized layer that will protect the copper from etchant)
1. i polish it witch some polishing paste, dont forget edges
2. clean the result with some alcohol or similiar to remove the paste and any smear (fingerprints), this can protect copper from etching away too, best thing is to use gloves from this point. dont touch the copper board with your hands
if it's polished and clean, its ready to be sprayed with photoresist or for hand drawing ...
i do all of this and i dont have problems, i use FeCl3
Mar 8, 2012. 4:01 PMecode says:
I have experienced the exact same thing.  After 24 hours or so it stops etching almost completely.  I believe this is due to all the oxygen leaving the solution.  You might notice that a new batch it will form bubbles as it out-gasses.
To me the plain HCL and peroxide solution seems useless unless you're just going to use it for one day.  It won't last any time at all in this form.  You can't store it in an airtight container because it will explode due to pressure building (a caution many people seem to forget on pages like this).   You can't add more peroxide (or acid) to rejuvenate the solution because you're adding mostly water when  you do this so it just makes things worse each time you do it.  I can't figure out why people think it's so great.  Maybe they're just using it once or I'm doing something horribly wrong.
I think the "end" solution of cupric chloride is the only proper thing that will last.  I'm in the process of trying to make this but it's slow going and difficult to manage.  What I did was use the same 1 part acid to 2 parts peroxide and then immediately start dissolving a specific amount of copper based loosely on the formulas on that other page (Adam's stuff; he doesn't say how to do it with peroxide) with a bubbler in the tank.  After a couple of days I still have a little copper left and my solution is turning brown.  My specific gravity is somewhat low so I'm hoping evaporation will improve that.  Not sure where to go from here.  I don't know what my acid level is so I don't know if I should wait a while longer and hope it greens up with the bubbler or if I should add more acid (that will reduce my specific gravity even more, not desirable).   The hardest part of this seems to be figuring out if you need more oxygen or if the solution is out of acid because you can't tell from the color of the solution alone.   I wish a simple pH test would work for the acid test, the titration procedure seems like a lot of hassle if you don't have lab equipment.
Mar 10, 2012. 6:29 PMvkoudymov says:
I think the trick to etching using this method is to get the copper concentration up. To do so, you need to get the copper to dissolve. Unfortunately, copper is very poor at dissolving in hydrochloric acid. However, if you can get copper oxide, that'll quickly dissolve/react in hydrochloric acid. I've put up an instructable on how to do this. Pictured below is the final product (takes about 30 minutes of prep, 5 hours of wait time).
Mar 11, 2012. 12:18 PMecode says:
Your instructable looks great.  That's definitely the way to go and I will probably use that method to increase my volume and balance my specific gravity.
Just an update on my original solution.  Once all the solid copper was gone it almost immediately turned green.  I added more acid and did the titration test.  I'm currently at 3 M acid (perfect) and specific gravity of 1.2 (too much water from my initial peroxide, for sure).
Feb 1, 2012. 4:52 PMconmac863 says:
I know this is an old post but I have a question.
I make the solution and put my copper (2X2 inch piece) in and it goes to town. First piece almost had to throw away because it was in there for about 20 minutes and almost etched all the way through. Worked great. I have it in a tupperware type container. Next day I went to etch another piece and nothing.... not even a little bubble. I let it sit for several hours and got the tiniest etch on it. Am I not storing the solution correctly or something?
Thanks and awesome instructable.
Jan 29, 2012. 10:15 AMsarbot says:
Unfortunately, the formula you are using with "pool acid" or technical grade HCL from hardware stores is still quite heavily contaminated with iron.
It's a well known fact in the industry.
Try using lab grade HCL and see if the iron free HCL works as well - - there may be an exchange principle involving iron in the reaction.
Jan 11, 2011. 12:10 PMjaydenr says:
Help, my mix just dissolves the copper. My muriatic acid doesn't tell me what percentage the acid solution is, it just says "industrial strength". will this start etching when more copper is dissolved in to it? what can i do?
Jan 26, 2012. 11:37 AMcincodenada says:
"Disolving the copper" is what it's supposed to do...that's what etching is: dissolving the unprotected copper from the board.
Oct 27, 2011. 12:29 AMTasDev says:
Here I go exhuming an old article but:
Excellent tips, tried it and etched a few boards with very good results and this could be the answer to my problem of now having to get Ferric Chloride (crystal form) by mail order in my locality.
Just one thing someone may be able to clear up for me though.
Adding the peroxide to my HCl which is 280-300g/litre makes the etchant dark brown so there's no way to assess the 'green-ness' of the mix. Tried with 2 different concentrations of standard hardware store acid with the same result but the etchant certainly does its job well so my only way of checking its state would be via specific gravity and ph. No amount of aeration with an air pump and a porous stone makes any difference to the colour or clarity.
Is there iron or some other contaminant in my HCl?
(Both the acid and the 6% peroxide appear perfectly clear & clean prior to mixing)
Also did some sample tests in test tubes with the resulting brown colour starting to develop from just a single drop of peroxide in 10ml of HCl.
Jan 20, 2012. 1:25 AMsilvermoonlyn says:
Mine went a weird rusty brown colour too. It's still working like a charm, but I have to keep checking to see how it's going. It would have been much easier if it was clear though. I might try and get some more hydrogen peroxide from a different source and start over. Can someone please tell me how I should dispose of this solution?
Nov 3, 2011. 9:47 AMrdemar says:
I'd also question the purity of the peroxide... Something is definitely amiss because I tried it for the first time today and the mixture remained water clear at 1 part HCl and two parts H2O2. The initial etch was just wicked fast - I had to clean the copper off a double-sided octagonal G10 copper clad plate for use in a quadcopter build, and it mowed ass on it, was a pleasure to watch. The result was one clean fiberglass plate and a beautiful emerald green solution. NICE. :-)
Nov 30, 2011. 12:58 PMaquietinspiration says:
What can I clean the copper plate with before ironing on my design? I have read that you can clean it with acetone and wipe it down with a paper towel but wouldn't that be dangerous since you may be mixing acetone with hydrochloric acid and peroxide??
Jan 11, 2012. 4:34 PMlee321987 says:
Scotch Brite pads seem to work pretty good (the hard, green ones).
Also, I've read that a very quick dip into etchant cleans it really good. I haven't tried that, but i do know that copper turns pink pretty fast after I put it into etchant (I think pink means it's REALLY clean).
I don't know what would help the toner adhere more though: the extreme clean of an etchant dip, or the added surface area from scuffing....???
Anyway... if you do scuff it, MAKE SURE YOU CLEAN THE LEFTOVER DUST really good!
Jan 3, 2012. 8:54 AMOrngrimm says:
I simply rub it with a fine iron-wool-sponge-thing.
I rub it till it shines really good.
Also I do the same to remove the toner i used to print the layout to the PCB.
Dec 24, 2011. 6:38 AMPranjal Joshi says:
this is quite good than stainy FeCl3...
thanx.. i ll try it
Nov 27, 2011. 10:23 AMmorrison427 says:
You can get the initial reaction to start faster if you use a higher strength H2O2 -- like from the beauty store -- but use only a tiny bit. Otherwise it'll outgas both excess oxygen AND chlorine for a while.
BTDT, got the acid-washed t-shirt.
Jim
Nov 25, 2011. 6:38 AMLectric Wizard says:
That should read " electro-plate other projects"
Nov 25, 2011. 6:37 AMLectric Wizard says:
GREAT IDEA !!! I thought there had to be a simpler way than that used in the other instructable you mentioned. I was wondering if you could use the used solution to copper plate other projects ... that would be real recycling !! Thanks for the Instructable !
Nov 18, 2011. 2:16 PMM2Field says:
To reclaim copper from "spent" solution and make the product disposable, just add excess aluminum. Foil, cans, scrap metal...
The aluminum is sacrificed to aluminum chloride and the copper is precipitated out as pure copper powder. Filter out, rinse clean and dry. Recycle at nearly $4 a pound.
Hey! At least the spent etchant is now disposable.
Nov 16, 2011. 10:09 AMipbobcat says:
I want to etch brass instead of PCBs. Will this technique work with brass as well as copper since it contains zinc, etc.?
Nov 4, 2011. 5:06 AMNinjawulluf says:
Be careful, those exact ingredient are used to make high explosive Acetone peroxide.
http://en.wikipedia.org/wiki/Acetone_peroxide
Nov 3, 2011. 9:40 AMrdemar says:
Wowww this is brilliant! I've been into electronic PCB fabrication since I was a teenager and all these many, many years I've basically had a love/hate relationship with Ferric Chloride. I wish I'd known about this from the start, it's fantastic! THANKS!! :-D
Nov 1, 2011. 1:59 PMescalix says:
hi people, i've been reading the article and the comments (seems u know a lot of chemistry) so i think that somebody could help me with my problem please, actually i drop some used ferric chloride over a concrete floor, the floor was never sealed with the expoy resin so i think it may have absorbed it, i didn't notice when it happened so it dry completely and now i don't know how to remove it easily. I've tried with some white vinegar and works well, not at 100%, but requires a lot of work; somebody told about the use of oxalic acid but when i ask for it at the store they tell me that is for cleaning marble so i'm not sure if it will work, any help will be really appreciated, thanks in advance and also i will try to follow this instructable, it's a great option instead of working with ferric chloride.
Oct 25, 2011. 8:42 PMAbbieX says:
So, I've etched a couple of things, and the copper came out of solution and is sitting on the bottom of the etchant tank (plastic tupperware container). I poured the liquid in a jar for later. What do I do with the blue residue in the bottom of the container?? Thanks, great Instructable!
Sep 7, 2011. 5:39 AMwilliebikes says:
Do you think I could use an old fish tank as my container for etching? or too big? or will the solution ruin the seals? thanks
Oct 5, 2011. 12:07 PMventure electronics says:
I used an old plastic peanut butter jar Put a prop from a video card on a small motor then hot glue it through the lid and your in buisness. I have done over 50 boards this way with great success.
Sep 21, 2011. 8:12 AMSparticles says:
FINALLY! I did it!
Almoast 2 months of trying, I have dozens of failed ones laying here but finally I made a pcb that should work.
My times are extremely long!
30 minutes lighting (blacklight)
two hours developing (very strong solution of NaSiO4 (google says I should just dip it in there for a couple of seconds.... no)
And finally 1,5 to 2 hours etching. (for a small board, so not the 2 minutes like this tutorial the concentration was 23% HCL )
Also it etched unevenly , some parts are nice and some parts I had to scrape off copper and in other parts the traces were beginning to etch away...
(next time I will try that printer method)
Don't get me wrong, I'm very pleased that it worked now, but has anyone an Idea what I'm doing wrong?
Oct 5, 2011. 12:05 PMventure electronics says:
This method of etching is the best. What I did was take a small propellor off a video card and put it on a motor. This will stir the solution and you should have at etch in about a half an hour. The etch always turns out evenly for me. I have tried many other methods and this one seems to work the best. The only problem I had was using a shiny paper for the transfer . I did finally find one. (toner method.).
Sep 21, 2011. 8:51 AMSparticles says:
When drilling holes in it, all my copper traces fell off :(
Oct 1, 2011. 8:31 PMblinkyblinky says:
If I add baking soda, it should neutralize...
It might still be poisonous, though.
1-40 of 475next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
93
Author:The Real Elliot
