Step 1Ingredients: The Starter Etchant
(OK, actually three. But the third one's copper. See the chemistry section for an explanation.)
Hydrochloric (muriatic acid, "pool acid", etc.) is available at a hardware store. The acid I got is 31.45% (or 10M) and should run around $5 per gallon. Which is more than you'll ever, ever need.
The peroxide is normal 3% for mouthwash or cleaning cuts, and can be bought at a drug store for $2-3 for a big bottle.
You'll also need a non-metallic container that fits your PCB and two standardized measuring cups.
As long as you're in the hardware store, pick up some acetone if you don't already have some. It's useful for removing the etch resist. (That's for another instructable.)
2 parts peroxide
? WATER
1 Part Muruatic acid
Are the steps correct because I really do not want to make a bomb
A base like sodium hydroxide in the right amount will neutralize the acid in the solution but there is no such thing as neutralizing cupric chloride. It is what it is.
If you could find some way of replacing the copper ion with a sodium ion then you would have table salt and that probably won't be a problem to dump down the sink. But cupric chloride will kill fish and other life forms in water.
