Step 4Chemistry Break
I stumbled on this idea when I saw this website: Etching with Air Regenerated Acid Cupric Chloride by Adam Sechelle. Cupric chloride can be re-used indefinately by topping up the acid levels and adding oxygen (bubbled in from the atmosphere). Sounds cheap and environmentally friendly to boot.
The website's got a lot of good chemistry info on cupric chloride etching. His data on etching speeds is great, and his simple titration procedure for maintaining the acidity of the solution is pretty nice.
To make the cupric chloride solution, he dissolves a bunch of copper wire in hydrochloric acid, and mentions maybe using hydrogen peroxide to speed up the oxidation, but doesn't go into detail.
Which got me thinking. You didn't have any cupric chloride yet, but you can make it by dissolving copper. Dissolving copper is the name of the etching game. So we can make one etchant that makes another etchant that's infinitely re-chargeable. Elegant.
Turns out that hydrochloric/peroxide is a common home-brew etchant (and I've re-re-invented the wheel, again) but I guess that people got so used to throwing away their "spent" etchant that they don't think about re-using it. The whole point of this instructable is that you don't throw it away, but use the dissolved copper forevermore as your long-run etchant.
Here's what's going on chemically:
Before there's much copper dissolved in the solution, Cu + 2 HCl + H2O2 -> CuCl2+ 2H2O is the dominant net reaction. That is, the extra oxygen in solution from the peroxide is oxidizing the copper metal, in presence of the acid, to make copper (II) chloride. That's our starter etchant. The resulting CuCl2 shoud be a nice emerald green color.
After you've dissolved a lot of copper into the solution, and used up all the peroxide, the copper chloride does most of the etching for you: CuCl2 + Cu -> 2 CuCl. That's the end etchant.
Eventually you etch so much that you convert all the CuCl2 into CuCl, which doesn't dissolve copper (and is a yucky brown color). As long as you've got enough acid in the solution, you can simply add more oxygen to re-oxidize the copper(I), making more copper(II) chloride and water: 2 CuCl + 2 HCl + O -> 2 CuCl2 + H2O. And then you can etch again.
Bottom Line:
Two things to maintain: CuCl2 levels and acid levels.
CuCl2: After all the peroxide is used up, and the solution starts turning brownish, you'll have to add oxygen to regenerate the solution again: toss in a few more capfuls of peroxide or bubble air through the solution or swirl it around vigorously, or just pour it into an open container and wait. It's easy to tell when you're ready to etch again, because the solution turns green.
It's also impossible to add too much oxygen by adding air, so bubble/swirl to your heart's content. If you're using peroxide to add oxygen, be sparing -- a little goes a long way, and it's mostly water so you're diluting your etchant by adding it.
Acid: Note that HCl is being consumed in the starter etchant and the regeneration reactions. So we're going to have to add a bit more acid as time goes by. If you notice that it's harder to re-green your brown etchant, it's probably time to start thinking acid.
I've tried the titration described on Adam's site a couple times, and it's pretty easy but requires an accurate scale and pure lye (back to the hardware store...). It's easier to just toss in a capful of acid every few batches of boards, which seems to do the trick for me.
sh*t you can just use the fishtank as well.
Props to The Ideanator
Bubbling can make a huge difference in etching speed and agitating is for the birds!
