3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Stops Any Type of Itching Fast!
video Stops Any Type of Itching Fast!
Applying heat with a common hair dryer causes controlled pain which counters and neutralizes any itch instantly. Pain stops as soon as the heat is removed. Works anywhere on the body, including private areas.
10 comments
May 29, 2012. 8:54 AMtafelice says:
I have done the hair dryer itch thing and it works. pretty long relief. I had moderate area poison ivy (or oak or sumac who the heck knows) and I combine first the hair dryer and then after a minute I sprayed it with extra hold hair spray. I get a couple of hours of no itching and I just respray. CAREFUL not to reverse the order as you might light yourself on fire, but at least there is good info on burn control, just kidding, DON'T light yourself on fire.
Thanks to the presenter for bringing the hair dryer thing to instructables.
Jul 30, 2008. 3:59 PMScott_Tx says:
Kind of overkill for a video. Blow dry the itch till it hurts. the end.
Apr 26, 2009. 1:54 PMcodongolev says:
what should he have done? an entire instructable?
Oct 16, 2008. 9:32 PMShyrric says:
Isopropyl alcohol (just a dab) works great on flea bites. I've yet to test it on other forms of itchiness. It burns like a mother****er if it gets into an open wound, though, so I'd definitely pass on itchy papercuts with this.
Aug 14, 2008. 1:56 PMkettir says:
Another method of applying heat, useable for poison ivy, is to use hot water. I have used a sink sprayer attachment to apply water as hot as I could stand it (but DO NOT SCALD YOURSELF, it doesn't help!) At first it stings, then it feels weird (my theory is that the nerve endings are shorting out at this point) and then you can stop treatment. You can get hours of relief from poison ivy with this method. It really works.
Oct 3, 2008. 11:44 AMquasarmeister says:
in addition, appling hot water to skin would make the toxics from the ivy more apt to spreading.
Aug 2, 2008. 10:08 PMdchall8 says:
I read this when it was first posted and had an opportunity to test it today. Seemed to work on a mosquito bite I got. I wonder if the heat cooks the enzymes that cause the itch. That's the only thing that makes sense to me.
Jul 30, 2008. 2:16 PMrobots199 says:
This must work but I will not try it because you hurt yourself to just stop a simple itch. Just to tell you, Pinching the itch while hairdrying it works the best. 4/5 stars
Jul 30, 2008. 2:17 PMrobots199 says:
BTW welcome to instructibles and great first instructible!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Johnny_B_Good
Simple web site designer. Creator of the fan site for the 1950's space adventure cartoon website www.TheSpaceExplorers.com
