Introduction
I created the StorageBot to help solve a problem experienced by most Makers. After many years of accumulating thousands of parts stored in storage bins, I began to go crazy looking for parts scattered between so many of these bins. The hardest parts to find were always those rare miscellaneous parts that were thrown somewhere into a "junk" bin. StorageBot solves the location problem by listening to my voice commands, processing the location of parts from a master database and then delivering the matching bins in a manner that only a robot can do!
StorageBot does have a bigger picture when it comes to purpose. I explain in my video that it's not about building a StorageBot that's important, but rather it's the skills we can learn from such projects that help to enrich our knowledge and inspire us to build the next great thing or start the next cool business.
In this Instructable you'll gain insights into the electronics, mechanics and software systems used to create useful projects by utilizing commonly available components such as the Arduino and stepper motors.
I've included a bazillion pictures and files. Source code for the Aduino program, source code for the Visual Basic voice recognition software, DXF files for the ABS parts, schematics for the electronics, 3D files drawn in the free Autodesk 123D program, parts list, etc... It's all here!
If you find this project inspirational and helpful then don't forget to vote for it in the ShopBot contest. I would use a ShopBot to create the ABS parts, aluminum parts and vaccuum form molds for my next generation home robots.
Enjoy!
Step 2: Autodesk 123D & Pine Frame
When buying pine wood from Home Depot make sure you spend time selecting the best pieces of straight wood. I found the wood at the top of the stack is typically the most crooked pieces. Some of this lumber may be returned items and obviously people would return the worst of the pieces. Here's a trick to help determine the straight pieces. Place the piece of wood on the flat concrete floor and use the floor as a straight edge. Stay away from wood that is twisted along the length. Long pieces of wood that bow slightly in the middle can be ok if a later process such as screwing into the final framing straightens them out.
I modeled the pine frame using the free 3D CAD program from Autodesk called 123D. You can download the program here:
http://www.123dapp.com
The cool thing about this program is that you model the components of your systems and then connect them together using something called constraints. In 123D constraints are under the Design Intent \ Assemble Icon. With constraints I can tell 123D to take 2 separate pieces of pine wood and align the edges to each other. Another useful feature of 123D is the Browser history along the left side of the screen. With this browser I can easily turn components on and off by just clicking an "eye" icon for each component. I used this feature in order to generate the step by step images for the frame construction.
The 123D model of the pine frame is attached below as a zip file. Have fun playing with 123D and be sure to watch the tutorial videos on YouTube.
Step 3: Building the x-axis
Like many Makers I sometimes struggle coming up with the best design approach. My first attempt at prototyping the X axis was unsuccessful due to binding issues. When building any rail system mounted to a wooden frame one has to compensate for wide build tolerances. For example: the wood isn't always straight, there may be warpage with temperature and humidity, cut lengths are slightly different, etc. The final solution I came up with was inspired by a rail system that was already used in my house. It so happens I have pocket doors and the rail system used on those doors can also be adapted to the StorageBot.
Pocket door hardware is an inexpensive and simple system for producing linear motion while hanging a lot of weight such as a door (or equivalent on the StorageBot). See the attached pictures on how I adapted this simple system. This is a great example of how being observant to the world around you can provide insights into solving problems.
Step 4: Building the z-axis
I already determined the z-axis would be belt driven and there would be a drive pulley and an idler pulley creating the ends of the belt system. When the belt moved it would have to move a carriage up and down in the vertical direction.
The challenge was coming up with a low cost way to guide the z-axis carriage along the vertical direction. There was already a vertical frame made out of wood so I wanted to use that as a guide. Using wood as a linear guide can be tricky due to sticking from friction. I finally came up with a solution based on some past tinkering with a bin full of spacers. Once again, curiosity paid off.
In the attached pictures you'll see how I used two different sized spacers, one made out of aluminum and one made out of nylon to form a low cost roller guide. Who ever knew playing with a bin full of spacers and noticing how some fit within others would pay off!
Step 5: Building the y-axis
The solution I came up with for the Y-axis was a rack and pinion system. The rack is essentially a toothed rectangular bar that is driven my a toothed circular "pinion" gear connected to a hobby servo motor. By picking the length of the rack and the number of teeth on the circular pinion gear I could now control the throw distance of the "finger". A rack and pinion system is another common way to convert circular motion to linear motion. In fact, it is used widely in the ShopBot system. See the attached pictures for the rack and pinion design. I'm fairly happy with the compactness and adjustability of this design when using different brand servos and different size pinion gears.
Step 6: Building the Electronics
The code running on the Arduino basically translates serial commands from the PC computer. These commands are then used to perform the following:
- moving the x-axis stepper motor
- moving the z-axis stepper motor
- moving the y-axis servo motor
- reading the x and z axis limit switch
- controlling the LED strip
Controlling stepper motors are very easy. Each stepper is driven by a driver board. By sending a step and direction signal from the Arduino to the driver board the motor can be made to move forward or reverse by one or more steps.
The servo motor for the y-axis is also very easy to drive. The servo actually contains a motor driver board internally. A certain type of digital waveform is sent to the servo to make it move anywhere between the extreme clockwise and counter clockwise positions. Scope captures of this servo waveform are in the attached pictures.
shopbot_win_rev6.zip22 KBStep 7: Voice Recognition Software
http://www.microsoft.com/download/en/details.aspx?id=10121
After installing the SDK be sure to train the speech engine by going to the speech setting under the Windows control panel for more accurate voice recognition. I found the speech recognition doesn't always work that great. I believe the stuff I've seen on the iPhone and Android devices where you can speak more naturally are much better. Nevertheless, the MS SDK is good enough to start experimenting with voice recognition technologies.
There are 2 main functions of the application software. One is to handle speech such as voice recognition and text to speech output. The second function is to take the voice commands and search for the associated parts and bin locations within a master database. This master database was originally generated in Microsoft Access.
Source code for the program is attached as a zip file. You will need Visual Basic 6.0 to modify and run the application.
storagebot.zip27 KBStep 8: Conclusion
I hope the many ideas presented in this instructable inspires you to create the next great products!
Visit Our Store »
Go Pro Today »
I've got 2 more instructables in the works and should have them up by the end of the month, then it will be only house projects for the summer.
Of course their is a certain appeal and shear coolness factor of the system ejecting the bins for you. Not to mention I love the the new use of a cnc system.
Another idea to upgrade the system would be to add a camera that could snap a picture of an object put on a shelf next to the computer (maybe it looks like a star trek replicator) and than have the computer find the matching parts in the bins, or associated parts. For example you put a 1/4 bolt in the "digitizing" area and the computer finds all 1/4" related hardware. Of course you could add motion activation to the camera with a small delay for automatic detection. Or alternatively a big red glowing button ( like an e-stop button) to the side of the star trek replicator style shelf, labeled "digitize".
I am really impressed with the new use of the cnc ( at least new to me) and see a similar system in the future for my shop ( although most likely with the LED grid). I run a product design, and retail company. Our prototyping lab is always becoming a mess amidst the messy internals of a project, and I need to add a more comprehensive organization system. Once again super awesome! And you've got my vote!
I converted a manual milling machine to CNC and used it to cut the plastic ABS parts in the Instructable. I tried to cut some ABS at the local FabLab but it stunk up the lab too much.
I just finished building a power draw bar for the mill which allows me to easily swap cutting bits with a foot switch. Here's a short video:
Anyway my point was the exhaust system allows me to cut plastics with zero smell. Not to mention the dust control.
What software are you using to control the cnc draw bar? Also how is it activated? Computer interface, something else? Or is this posted as an ible somewhere that will answer my questions?
I meant to say using a laser cutter on ABS stunk the lab up. Using my mill wasn't bad at all for smell because I can run only up to 2000 rpm.
I use a foot pedal that controls a pneumatic solenoid 12 volt valve. The valve controls the compressed air going to the giant pneumatic cylinder on the top. The cylinder pushing down on some spring washers that releases the tool holder from the collet. This system was based on many other designs described on CNCZone forum.
The tool holders are called TTS from Tormach. It is designed for an R8 spindle common on mills. Routers don't use this type of spindle so a quick change is a bit more difficult. Here are some pics. Hopefully they can be viewed in full resolution.
Anyway really happy for you! Good Job! I think you will do great things with the shopbot!
Just use your friends as test subjects to get your bearings about the particulars of the machine. And give them a disclaimer that there's a chance for messing up. Good way to make them pay you back, even if it's intangible experience; plus you don't carry the burden of buying test material.
Here's one project I did with my machine.
Big congrats to you... now please come to my house and build me one? ;-D
Now imagine each bin has a unique RFID tag and there is an RFID reader attached to the Z carriage. The Z carriage can now sweep past every coordinate location, read the RFID tag, and update the database locations or alert the user if the bin is in the wrong location.
I'm in Seattle, and we have one of the most-utilized library systems in the country, but falling tax revenues. This has meant cut library hours and worse.
So I thought it would be nice if the library had neighborhood pickup boxes for your library items. They'd be like vending machines, but with your books, CDs, DVDs, etc in them. Scan your card, enter your pin, and your hold drops out (you'd get an email through your account telling you when your hold was available.)
(First of all, my apologies, my english isn't very good).
I'm about to start building my own workshop (well, not me, people that knows about bricks and that sort of stuff) and I was puzzling my mind on how I can resolve some similar system.
Your idea was far better and simpler, I always apreciate that, KISS.
My plan was to do some kind of arm, that would be flexible enough to diferent box sizes and positions, but this scheme is as flexible, and much easier.
Again, thanks, I hope you win the ShopBot challenge, regreatably, I got here too late to cast my vote.
Excellent Work!!!!
http://arduino.cc/playground/Learning/WhatAdapter
