Introduction: Stormtrooper Cut-Out Shirt
Over the last while, one of the most popular crafts floating around the internet has been the skull cut-out shirt, such as this one by scoochmaroo. It's appeared on craft site after craft site, Pinterest board after Pinterest board, and I decided to give it a new, nerdy twist - converting the skull into a Stormtrooper.
Also, please remember to vote for me in the Remix contest if you enjoy this Instructable!
Step 1: Print Your Template
Print out the template you want to use. I printed mine on two pieces of paper and sellotaped them together. For this kind of project, I found that some pumpkin carving patterns are perfect, so that's where I found this pattern (pattern does not belong to me).
Step 2: Laminate the Template
Cut the template to A4 size if necessary, and laminate it. This step is optional, but helps to make a durable stencil that holds its shape well. Cut out the parts of the template that will be cut out on the shirt.
Step 3: Trace Your Template
Tape your laminated cut-out template onto your shirt, and trace the cut-out areas with a tailor's pen.
Step 4: Cut Out the Template
Cut out the spaces inside the traced gaps, creating your Stormtrooper cut-out design.
