3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Stovetop Kool-aid Dying using Alum as an modant
this is an instructable on how to use alum as a mordant (something used to help fix dye to fiber) to pre-treat wool yarn so the dye will be permanently set in the fiber. Also how to dye yarn using Kool-aid on a stove top. You can skip the kool-aid step and use your own dyes or natural plant dyes instead.
I found the recipe for the Alum mordant at : http://www.allfiberarts.com/library/howto/ht00/how_alum_mordant.htm
Step 1What you need
what you need
For the pretreatment you'll need:
Alum
cream of tarter
gloves
yarn in a light colour it needs to be wool
scissors
a scale
2 chairs
spoons
metal pots NOT aluminum or cast iron
For the Kool-aid dyeing:
Kool-aid
vinegar
yarn
measuring cups
yarn
spoons or tongs
gloves
19 comments
Apr 4, 2012. 5:04 PMloveofthedark says:
Kool Aid is a natural Acid Dye. It doesn't require a mordant.
Alum, Cream of Tartar, even vinegar are completely unnecessary for Kool Aid Dyeing.
I've been dyeing fabrics and rovings, and yarns for 10 years, and this is how I know.
Apr 23, 2008. 10:47 AMJake-off says:
would you be able to dye your hair if you added a solidifier,such as guargum, to the substance
Nov 29, 2011. 4:53 PMSulwen says:
Wait wait wait. Sorry. I know this is a thousand years old in internet time, but "Alum is a chemical and as such might be bad for you"?
Um. You did notice that it's a food product, right?
Chemicals are in everything. Sodium Chloride is a chemical. It's also table salt. Sodium Bicarbonate is also a chemical. It's baking soda. Citric acid is a chemical that's naturally found in fruit.
Apr 12, 2010. 6:19 PMxbelindabillyx says:
You should weigh the yarn before you get it wet instead of after.  Recipes are always given for dry weight, because you never know how much weight you are adding with the water.
Sep 9, 2009. 10:46 PMRich T says:
Hey, I've seen Warner Bros. cartoons, and the only thing alum does is make your head shrink and your voice get real high pitched ;)
Nov 8, 2008. 9:55 AMallbeef says:
I am making fingerboards (mini skateboards) and do you think that the dyes would penetrate the maple veneer fully so that when I cut the shape the dyes can be seen from the side?
Mar 31, 2009. 1:40 PMsilverrowan says:
why are you using alum as a mordant? cooled doesn't really even need vinegar to set either - strait food coloring needs an acid though. But everything I've found up to now doesn't require anything beyond vinegar as a mordant for protein fibers (ex. wool, silk). Alum seems like overkill to me, and increases the toxicity of what you're working with, however if it has a practical use I'd love to know. Thank you.
Apr 14, 2009. 9:45 PMcycadia says:
Hmmm, I think you'll find that many plants (ie non-substantive dyes) are fugitive without a mordant. Vinegar is not strictly a mordant but can help sometimes. See http://www.griffindyeworks.com/mordant_info/vinegar.html and http://www.griffindyeworks.com/mordant_info/alum.html . Alum is a classic mordant, and very low in toxicity compared to other commonly used metal salt mordants (it's a food additive so I'm sure it's safe to dye with if you don't drink the water, plus it's safe to dispose of). Alum, as well as helping form a chemical bridge between many dyes and the fibre, can really increase the brightness as well. It doesn't tend to shift shades though, unlike other mordants. I've only started researching natural dyeing for a week, and this is what I've learnt from a million billion places from many experimental, empirical and often environmentally-minded sources and I doubt everyone is simultaneously misguided you know, silverrowan? But I'm glad the plants you are using are colour and lightfast with vinegar - if you could share their latin names I'd love to know! Thankyou.
Apr 15, 2009. 7:28 PMcycadia says:
That's really gorgeous! Have you got an idea of colour/light-fastness with/without alum yet? (Guess it depends upon the fibre/dye combo though.)
Jun 22, 2008. 12:06 PMpebbles1 says:
could you dye mohair the same way????
Jun 22, 2008. 7:28 PMpebbles1 says:
ok iam confused do i need to add soemthing besides the koolaid to the mohair?????thanks for your help
Jun 23, 2008. 10:05 PMpebbles1 says:
thank you phantom iam going to try it tommorrow with some white wool i think all the diff koolaid colours would look awesome as granny squares.
Jun 3, 2008. 10:47 PMYerboogieman says:
my favorite is the ice blue raspberry lemonade
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Winged Phantom
