Friction is a function of surface contact area, force and the coefficient of friction. When I car-top my kayaks, these three variables are what I have to work with.
Ratcheting up the force is the simplest way to increase the holding friction. However, this can strain and stress a boat, an expensive investment to damage!
Commercial racks increase the surface contact area with special cradles. Unfortunately, these are expensive and reduce the general function of the rack.
Sleeves of non-slip rubber to augment the friction easily secure my boats. It's cheap and general, rather than brute force or elaborate racks. A more simple solution.
Remove these ads by
Signing UpStep 1Materials and Tools
As you can see, my long boat is a simple roto-mold plastic boat, but cracking up the force bends the hull shape way too much. In this case it is the cheap hull materials that are the issue. Certainly with racing boats it is protecting the expensive hull that is the concern.
BTW- although the scrunchy material is gentle on hulls, it does retain sand. For a performance, gel-coat hull, I'd slip a clean chamois between the wraps and the hull. Definitely don't want to loose the gloss!
Nice write up!
All said, it's doing good (by my estimates) for 150K. Probably buy a new car next year, then drop 5K to clean up this one.
BTW- you should see my old car...
Crazy that just going simple and sloppy actually works best!
