loading
Step 2: Another View
This provides another view of the lateral bracing to keep the bikes abreast.
<p>Not a Bad Idea, I am going to attempt to build a recumbent style <br>quad, using a Captains Chair I bought that doesn't fit in the van, I am <br>going to let ford repo, 2015 piece o' crap. Just purchased two 20&quot; Fat <br>tire mongoose bikes from walmart, 28 good reviews The Challenge, Join <br>the two bikes together using Electrical Aluminum Rigid, and at the same <br>time use that pipe as a platform to mount the seat, I am considering <br>using the Inside Pedals from each crank to pedal the contraption, and <br>build a steering linkage to turn the front wheels. </p><p>If anyone has an Idea on How to Join the Two Cranks into one, Let me Know !!</p><p>Could be as simple as a couple of rod couplings and some rod, Locktite, and some jam nuts or Piece of Crank shaft, Pipe for a trike and move one crank to the center and bearing in the housing where the cranksets normally go ?</p>
Have you actually tried this? I would say that given that steering a bicycle is more about weight shifting than actually turning the steering column that linked parallelograms (as seen on some three-wheel motor scooters) would be better than trying to make a rigid rectangle.
<p>Someone in Bristol has apparently done this, but I haven't found any more info yet. See at the start of this video: https://youtu.be/QtGEby4ORGM</p>
<p>Actually, when you connect 2 bikes side by side, you get the exact same scenario as your car. The only reason leaning comes into play on a bicycle is because you are balancing on 2 wheels.</p>
<p>It's a faith-based instructible. You just have to take the author's word for it.</p>
No, I have not tried it. I did this as a suggestion for the lady who wanted something like this.
great idea. <br>i intend to join two identical dumpster BMX bikes with three transverse steel tubing rods secured by 12 &quot;u&quot; bolts. steering : i thought to simply drill each handle bars top at near centre and join then with a light rod. the entire arrangement will be a bit unwieldy but will provide a means for a pal to cycle with his spina bifida son
I love popular mechanics!!!!
Take a look at <a href="http://www.google.com/url?q=https://www.instructables.com/id/Great-Projects-from-Old-How-to-Magazines/&sa=U&ei=1TXgTrzRCuzYiAKNtvyWDw&ved=0CAQQFjAA&client=internal-uds-cse&usg=AFQjCNELcxCfTP7OgA4dOVvZeyvr_vhQMw" rel="nofollow">this Instructable</a>. It will take you to all back issues of <u>Popular Mechanics</u> and <u>Popular Science</u>&nbsp;on-line. You can read those magazines to your heart's content.
Thanks for your time Phil B, very nice instructable! <br>I will start to build it right now.
Another alternative for joining two bicycles into a Tandem Equivalent is available at: <a href="http://TinyUrl.com/TandemEquivalent" rel="nofollow">http://TinyUrl.com/TandemEquivalent</a>&nbsp;<br> <br> This solution would not work for the expressed purpose of carrying groceries, but it is good for two people who want to cycle together.&nbsp; One big advantage is that it's easy to carry the two bikes and the tandem equivalent on a normal car bike rack.
<p>I have been thinking along this line also but for two riders.&nbsp; I know a few people with disabillities who ride trikes in their neighborhood but aren't able to access the beautiful trails we have around here because their endurance limits their range and their trikes aren't transportable except with a truck or very expensive rack.&nbsp; This is also a problem for people with traditional tandems.&nbsp; By combining two normal size bikes and making them able to&nbsp;be&nbsp;seperated you can have the stability of four wheels and also allow&nbsp; a stronger rider to assist a weaker friend while enjoying a change of scenery.&nbsp; In my area (Seattle)&nbsp;the buses also have bike racks and routes connect to many trails.&nbsp; It also gives you the opportunity to pick up a friend who's willing to ride but doesn't own a bike or lives/works in high theft area.&nbsp; Sorry I'm rambling but anyhow I found two commercial options.&nbsp; They are a little pricey but not everyone can figure this out on their own.&nbsp; You can also just take a look for ideas.<br /> <br /> <a href="http://www.thegrannybike.com/" rel="nofollow">http://www.thegrannybike.com/</a>&nbsp; or<br /> <br /> <a href="http://gandydirect.com/products/pedal-partner-kit/" rel="nofollow">http://gandydirect.com/products/pedal-partner-kit/</a></p>
It seems to me that removing the fork off the second bicycle and using it like a sidecar would solve steering geometry problems.&nbsp;
That would be fine, as long as very little weight was placed toward the front of the second bicycle. &nbsp;I think steering geometry problems under general use will be less than some anticipate.
In reference to jtobako's concern as to the cornering... this problem can be overcome by using 'Ackerman' steering. Basically, the tie-rod arms are attached at an angle so they both point directly towards the rear axle. This will allow the inner wheel to turn at a slightly tighter radius than the outer, thus eliminating the 'scuffing' problem. To get a better understanding, just take a look at any go-kart or riding mower.
another cool instructable would be an attachment you could use for riding with a dog running along side
the one instructable that i want to see is for a bike side car
YES A SIDECAR WHAT A CLASSIC THAT WOULD BE ANYONE HAVE IDEAS
That would be interesting. It would be complicated by the need for a circle kept free of bracing and structural components for the feet and the pedals to work. It might be easier on a stretch frame for a cargo bike where there is extra space between the seat post and the back wheel.
Thanks a million Phil B - or, if you want it in real Irish <em>Go raibh mile maith agat! </em>. I didn't expect such prompt or comprehensive help, I'm very grateful. Will definitely try this as soon as I can find a second, cheap or free, bike! And re your reply to jtobako, yeah, believe me - on these hills, I won't be doing any speed or any sharp cornering. I'm lucky to get up them without having to get off and walk...<br/>
I had another idea for materials you could use to make the bracing between the two bikes. It is 1/2 inch electrical conduit, sometimes known as electrical metallic tubing (EMT). It is not very expensive and quite rigid. It is also thin enough that a vise or a big hammer can be used to flatten the ends of a piece, which can then be drilled for "U" bolts. Done right, it can also be bent without putting a crimp in the tubing. it is easy if you can get access to a conduit bender. You can also cut a wooden disc about 8 inches in diameter and use it as a form around which to bend conduit. It is another option with some advantages over some other materials.
Jan, Thanks for your note posted here. I am glad you saw my suggestions for you. This is probably one of the very, very few Instructables done for the benefit of just one person; but others seem to be interested in it, too. On bicycle forums people frequently ask how they can get a bike on a low budget. Frequent answers include 2nd hand stores, rummage sales, and scrap yards. I do not know about Ireland, but in the USA the local police usually have an auction of unclaimed property about once a year. Often there are lost or stolen bicycles in the lot. At a scrap yard you might be able to find a frame from one bike and a wheel or two from another. I once bought a decent set of derailleurs at a scrap yard for only $5, just for comparison.
I think a plywood board across the upper part of the rear wheel frame and an as-wide-as-possible board connecting the fork tubes in the front would cover most stability issues. Make the steering bar as adjustable as possible, because the turning radius is going to be messed up. If the rest of the bracing and load will handle it, remove the front wheel entirely.
Plywood has good stability. It does also add wind resistance.
If you are worried about the wind, cut the center out. I'd be more worried about the cornering (swerving) ability at any speed, where the front tires aren't lined up to turn at different radii (the outside and inside wheels want to turn on the same circle rather than circles with a common center, if that makes sense).
The lady who wants this bike setup will use it to travel four miles to buy her groceries and bring them home again in somewhat hilly country. I expect her cornering will be pretty tame and mild. Even if the geometry is not perfect for swerving, it will likely do for her just fine. And, when you start cutting large holes in a plywood piece, it is no longer nearly as strong as it was before.
About This Instructable
43,394views
5favorites
License:
Bio: I miss the days when magazines like Popular Mechanics had all sorts of DIY projects for making and repairing just about everything. I am enjoying ... More »
More by Phil B:Easy Monitor for NordicTrack Skier Uses for Spent K-Cups Make a Conduit Bender
Add instructable to:
